Introducción
You’ve fixed your leaky roof and replaced the wet insulation in your attic—now what do you do about the unsightly hole over your head where that soaking mess dripped through your gypsum ceiling? You cut a piece of drywall to fit, fasten it securely, fill in the gaps with joint compound, and smooth out the patched areas to match the texture of your undamaged ceiling. Paint to match and voila! you can check your ceiling off your “to do” list! This guide will show you how.
Safety first
A few basic precautions will get you through this repair safely and successfully:
- Reduce tripping hazards by clearing furniture, pets, and people from the area under the repair
- Use drop cloths or painter’s cloths to cover the repair zone and group your tools and materials several feet from the base of your ladder
- Place the ladder squarely beneath the area you’re repairing so you won’t overextend your reach or get overbalanced
- Ask a friend to help if materials are too heavy or awkward for you to handle on your own
- Always wear eye protection when working with materials above your head
Qué necesitas
Determine the distance to the rafters on each side by measuring above the ceiling to the center of the exposed beam. Pic 1.
Add 3/4" to that measurement and measure the same way below the ceiling. This ensures your cut will be made along the approximate center of the rafter. Measure and mark with a pencil at several points, then draw through them to mark the cut lines you'll make right up the center of the ceiling rafter on each side. Pic 2.
Starting at the end of the rafter in the middle of the hole, measure outward to a point where the ceiling is undamaged. Mark it at the center and on each side, then draw a line through to intersect with the lines drawn up the centers of the side rafters. Pic 3.
Cut by laying the framing square flat on the ceiling parallel to the area to be trimmed away and drawing the blade of your utility knife straight down along its edge, making a clean, shallow cut in the solid material. Pic 1.
Support the piece being cut away with your free hand, deepening the cuts until you have cut completely through and the damaged piece can be removed. Pic 2.
Stabilize the sections of undamaged ceiling around the opening with drywall screws placed a little back from the edge—this helps to avoid crumbling or buckling of your nice, clean-cut edge. Pic 1.
Use enough pressure when driving screws so that the screw heads imbed slightly into the wallboard surface.
Hold the screw gun at a slight angle and drive screws into the side rafters, starting the screws a little back from the edge as before. Pic 2.
Dry fit the new piece into position (don't attach yet). It should be flush with the existing ceiling, rest on half a ceiling rafter on each side, and have a slight gap around the edges. Pic 1.
Dry fit again after trimming. Use the framing square and pencil to draw a line from the trim arrow to the ceiling arrow you marked in Step 4. Pic 2.
Slide the new piece into position. Hold it in place with the forearm of your free hand as you affix the new piece to the middle ceiling rafter along your penciled line. Pic 1.
Attach the new piece to the rafters on each side, placing the screws a little back from the edge as before and angled slightly into the rafter. Pic 2.
Anchor both sides with screws spaced evenly from corner to corner. Pic 3.
Use the 3" putty knife to scoop up the pre-mixed joint compound and apply liberally along the mesh tape, working the joint compound through the mesh holes and completely filling the gaps along the wallboard edges. Pic 1.
Continue working your way along each cut line, smoothing the joint compound along over the top of the mesh tape to cover it completely, both lengthwise and side to side. Pic 2.
Switch to the 6" taping knife and continue applying joint compound in smooth swaths, working both side to side and lengthwise along the repair lines, until you have a flat, uniform layer that feathers over onto the existing ceiling. Pic 1.
Your layering should completely conceal the mesh tape; pay particular attention to overlapped corners where it is thicker—the idea is to blend the new piece with the existing ceiling so the repair isn't obvious. Pic 2.
Use joint compound to fill the slight depressions over each screw and any blemishes in the surface of the new piece. Pic 3.
When dry, sand repaired areas lightly with 100 grit sandpaper or sanding sponge. Sand in a circular motion with light pressure so the area is smoothed but doesn't cause the mesh tape to become exposed. Pic 1.
For popcorn ceilings, pat repairs with a lightly dampened sponge after sanding, then apply the popcorn mixture with the 6" taping knife. The mixture is heavy and soggy, so apply a thin layer and let dry, then apply additional coats until the texture matches the rest of your ceiling. Pic 3.
Repairing a hole in your ceiling is more time-consuming than difficult, and now, doesn’t it look nice? Good job!
