Saltar al contenido principal
How to Repair a Hole in an Air Mattress
Qué necesitas
  1. How to Repair a Hole in an Air Mattress, How to Repair a Hole in an Air Mattress: paso 1, imagen 1 de 1
    • Inflate the air mattress fully using either a manual pump (pictured) or an electric pump.
    • An electric pump will save you time and energy so if you have that option definitely choose the electric pump, but know that means you need access to a plug.
  2. How to Repair a Hole in an Air Mattress: paso 2, imagen 1 de 1
    • Identify the location of the hole.
    • Some techniques to locate holes are listening for air escaping or using soapy water.
  3. How to Repair a Hole in an Air Mattress: paso 3, imagen 1 de 1
    • Clean around the hole where you plan to put the patch.
    • Use water and allow to air dry.
    • This will ensure a clean surface to attach the adhesive.
  4. How to Repair a Hole in an Air Mattress: paso 4, imagen 1 de 2 How to Repair a Hole in an Air Mattress: paso 4, imagen 2 de 2
    • Apply flexible adhesive made for vinyl where the patch is intended.
    • Use a brush or towel to spread adhesive to form an even layer.
  5. How to Repair a Hole in an Air Mattress: paso 5, imagen 1 de 2 How to Repair a Hole in an Air Mattress: paso 5, imagen 2 de 2
    • Apply a piece of vinyl patch on top of the adhesive to cover the hole.
    • Smooth out patches to ensure there are no bumps or bubbles.
    • You can smooth out bubbles with your fingers or use a plastic card.
  6. How to Repair a Hole in an Air Mattress: paso 6, imagen 1 de 1
    • Allow the adhesive to fully dry per adhesive instructions before using the air mattress.
    • Enjoy your fixed air mattress!
Conclusión
To fill any other holes, repeat the same steps as many times as necessary.
Senia
Miembro Desde 02/20/24
133 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 24
Todo El Tiempo: 77
