Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
Ever have that problem where you have to hold your phone just right to get sound through your headphones? Have you considered having a loose wire or a bad jack? This guide will help you replace that bad jack so you can get your tunes back.
  1. Get all of the tools and parts together and ready for use.
    • Get all of the tools and parts together and ready for use.
  2. Use wire strippers to cut off the broken headphone jack. Be careful when using the wire strippers. Handle them like you would with scissors. Keep the cutting end away from your body.
    • Use wire strippers to cut off the broken headphone jack.
    • Be careful when using the wire strippers. Handle them like you would with scissors. Keep the cutting end away from your body.
  3. Disassemble the new headphone jack. Measure the inside length of the new headphone jack.
    • Disassemble the new headphone jack.
    • Measure the inside length of the new headphone jack.
    • Add half an inch to the length you measured, and mark the new length on the old headphone wire.
    • Clamp the wire strippers around the wire where the mark is. Press tight enough to cut through the insulation but not the wire. Pull (Strip) the insulation from the mark to the cut end.
  4. Put the exposed cord through the metal and plastic sleeves of the jack, as shown.
    • Put the exposed cord through the metal and plastic sleeves of the jack, as shown.
  5. Kit de Destornilladores Manta
    112 bits for every fix.
    Upgrade Your Toolbox
  6. Separate the wires by color. Make sure that they are not touching.
    • Separate the wires by color. Make sure that they are not touching.
  7. Place the jack in the helping hands stand. Solder the ground wire to the bottom terminal. Check out this awesome guide on How To Solder and Desolder Connections.
  8. Solder the green wire to the left terminal. Solder the green wire to the left terminal.
    • Solder the green wire to the left terminal.
  9. Solder the red wire to the right terminal. The soldering iron is hot. It may cause severe burns if it comes in contact with skin. The soldering iron is hot. It may cause severe burns if it comes in contact with skin.
    • Solder the red wire to the right terminal.
    • The soldering iron is hot. It may cause severe burns if it comes in contact with skin.
  10. Push the plastic sleeve back over the jack to cover the solder points. Apply electrical tape if desired. Push the metal sleeve over the plastic sleeve and connect to the jack.
    • Push the plastic sleeve back over the jack to cover the solder points.
    • Apply electrical tape if desired.
    • Push the metal sleeve over the plastic sleeve and connect to the jack.
  11. Test the headphone by plugging it into a computer or music playing device.
    • Test the headphone by plugging it into a computer or music playing device.
    • If there is adequate sound coming out of both headphones then you have successfully repaired the headphone jack. If not, take the sleeve off and check if the soldering points are still connected and nothing has broken off.
Linea de Meta
26 personas más completaron esta guía.
andrew
Miembro Desde 18/03/15
744 Reputación
1 Guía escrita
Usage correction: that's not the jack. That's the plug you're fixing. Jack refers to the receptacle (female) into which one inserts the plug (male.)
linuxusergroup - Contestar
British say plug rest say jack
Narendra - Contestar
Or even jack plug. Then the female receptacle becomes the socket. Got to love the Brits!
David James - Contestar
For inventing the language?
Bryan Janes -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 631
Ultimos 30 días: 5,182
Todo El Tiempo: 106,958
