Introducción
Tired of replacing old headphone sets? Here’s a step-by-step guide on repairing frayed headphone cables in an environmentally efficient and affordable way. This guide will require soldering skills.
Qué necesitas
Cut above the frayed portion of the cable using wire cutters.
Using the wire cutters, strip away approximately one inch of wire coating.
36 personas más completaron esta guía.
2 comentarios
To me, the more difficult part in this job, is solder.... Now, If you are not sure, with where solder each wire, try with a tester in the continuity mode, and test between the each part of the tip and the three holes. Greetings!
