Saltar al contenido principal
How to Repair a Faulty Keyboard Key on a Toshiba Portege Z30-C
Qué necesitas
  1. How to Repair a Faulty Keyboard Key on a Toshiba Portege Z30-C, How to Repair a Faulty Keyboard Key on a Toshiba Portege Z30-C: paso 1, imagen 1 de 1
    • Make sure your laptop is fully powered down and unplugged to avoid sudden shock.
  2. How to Repair a Faulty Keyboard Key on a Toshiba Portege Z30-C: paso 2, imagen 1 de 1
    • Look for any obvious debris or obstructions. If there's any loose visible particles, use compressed air to blow it out.
  3. How to Repair a Faulty Keyboard Key on a Toshiba Portege Z30-C: paso 3, imagen 1 de 1
    • Using a plastic prying tool, carefully pry off the keycap. Insert the tool under a corner of the key and apply gentle upward pressure. The keycap should pop off.
    • Use minimal force to make sure you don’t crack the keycap.
    • Store the keycap in a small container so it doesn't get lost.
  4. How to Repair a Faulty Keyboard Key on a Toshiba Portege Z30-C: paso 4, imagen 1 de 1
    • Underneath the keycap, you'll find a key retainer and possibly a rubber dome.
    • Take a picture of the mechanism if needed to note how they fit together before moving on to the next step.
  5. How to Repair a Faulty Keyboard Key on a Toshiba Portege Z30-C: paso 5, imagen 1 de 1
    • Carefully remove the key retainer. This may require gentle prying with the prying tool.
    • Be very gentle to make sure you don’t break it.
  6. How to Repair a Faulty Keyboard Key on a Toshiba Portege Z30-C: paso 6, imagen 1 de 1
    • Use a cotton swab moistened with isopropyl alcohol to clean around the exposed area. Clean the key retainer and underside of the keycap as well.
    • Be careful not to drench the cotton swab; excess alcohol can seep into small openings causing damage to the electronic components.
  7. How to Repair a Faulty Keyboard Key on a Toshiba Portege Z30-C: paso 7, imagen 1 de 1
    • Allow the alcohol to air dry and evaporate completely. This should only take a few minutes.
  8. How to Repair a Faulty Keyboard Key on a Toshiba Portege Z30-C: paso 8, imagen 1 de 1
    • Reassemble the key. Start with the key retainer, snapping it back into place.
  9. How to Repair a Faulty Keyboard Key on a Toshiba Portege Z30-C: paso 9, imagen 1 de 1
    • Position the keycap over the retainer and press down firmly. You should hear a snap as it locks back into place.
Conclusión
After following these steps, your keyboard should be restored to optimal functioning. Remember, regular cleaning and maintenance can prevent sticky keys and prolong the lifespan of your laptop keyboard. Happy Typing!
Hadi
Miembro Desde 05/28/23
169 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 228
