Introducción
One day, you turn your Eufy Robovac 15C Max on, and it spins in circles. You've updated the software. You've read about how dark flooring can confuse the Eufy Robovac, but your carpet is the same as ever.
This guide is to disassemble and clean the Eufy Robovac, which will fix erratic or circular driving.
These instructions apply specifically to the Eufy RoboVac 15C Max. Model number: T2128.
Qué necesitas
Remove the RoboVac from its charging station.
Flip it onto its back to expose the underside and wheels.
Herramienta utilizada en este paso:Microfiber Cleaning Cloths$3.99
Use a microfiber cloth to clear away any debris.
Ensure that the bumper's two small lever arms spring back when pushed in.
Replace if necessary.
Your Eufy Robovac should be ready to go! Test the device by turning it on.
4 personas más completaron esta guía.
Un comentario
Is there any way to get a replacement metal clip that holds the swivel wheel in place? mine appears to have broken, and I'm out of warranty.
