Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Repair a Cracked Mirror
Qué necesitas
    1. How to Repair a Cracked Mirror, How to Repair a Cracked Mirror: paso 1, imagen 1 de 1
      • Clean the mirror with soap and water.
      Pregunta a FixBot
      Agregar Comentario
    2. How to Repair a Cracked Mirror: paso 2, imagen 1 de 3 How to Repair a Cracked Mirror: paso 2, imagen 2 de 3 How to Repair a Cracked Mirror: paso 2, imagen 3 de 3
      • Remove the adhesive backing of the stabilizer film.
      • Press the stabilizer film over the crack.
      • Use your fingers to smooth out the stabilizer film.
      Pregunta a FixBot
      Agregar Comentario
    3. How to Repair a Cracked Mirror: paso 3, imagen 1 de 1
      • Fill the syringe with epoxy resin.
      Pregunta a FixBot
      Agregar Comentario
    4. How to Repair a Cracked Mirror: paso 4, imagen 1 de 2 How to Repair a Cracked Mirror: paso 4, imagen 2 de 2
      • Insert the tip of the syringe through the stabilizer film.
      • Push down the plunger to fill the crack with resin.
      Pregunta a FixBot
      Agregar Comentario
    5. How to Repair a Cracked Mirror: paso 5, imagen 1 de 1
      • Set a timer for 20 mins and wait for the resin to harden.
      Pregunta a FixBot
      Agregar Comentario
    6. How to Repair a Cracked Mirror: paso 6, imagen 1 de 1
      • Peel off the stabilizer film.
      Pregunta a FixBot
      Agregar Comentario
    7. How to Repair a Cracked Mirror: paso 7, imagen 1 de 2 How to Repair a Cracked Mirror: paso 7, imagen 2 de 2
      • Add a drop of resin over the crack.
      • Cover the resin with the curing film.
      Pregunta a FixBot
      Agregar Comentario
    8. How to Repair a Cracked Mirror: paso 8, imagen 1 de 1
      • Set a timer for 1 hour and wait for the resin to cure.
      Pregunta a FixBot
      Agregar Comentario
    9. How to Repair a Cracked Mirror: paso 9, imagen 1 de 2 How to Repair a Cracked Mirror: paso 9, imagen 2 de 2
      • Remove the curing film.
      • Scrape away any excess resin using the razor blade.
      • Use caution when handling the razor blade as you do not want to cut yourself during the process.
      Pregunta a FixBot
      Agregar Comentario
    10. How to Repair a Cracked Mirror: paso 10, imagen 1 de 1
      • Clean the area with glass cleaner.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Marriam Shaikh
Miembro Desde 09/18/23
181 Reputación
1 Guía escrita
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 49
Ultimos 7 días: 258
Ultimos 30 días: 1,232
Todo El Tiempo: 10,826
