Saltar al contenido principal
How to Repair a Cracked Flower Pot
Qué necesitas
  1. How to Repair a Cracked Flower Pot, How to Repair a Cracked Flower Pot: paso 1, imagen 1 de 2 How to Repair a Cracked Flower Pot, How to Repair a Cracked Flower Pot: paso 1, imagen 2 de 2
    • Remove any contents from the pot.
  2. How to Repair a Cracked Flower Pot: paso 2, imagen 1 de 1
    • Apply craft adhesive along the broken portion of the pot.
    • Warning: your adhesive may be flammable. Carefully read the cautions listed on your adhesive before proceeding.
  3. How to Repair a Cracked Flower Pot: paso 3, imagen 1 de 3 How to Repair a Cracked Flower Pot: paso 3, imagen 2 de 3 How to Repair a Cracked Flower Pot: paso 3, imagen 3 de 3
    • Begin to apply glue onto the broken pieces.
    • Once you apply glue to a piece, attach it to the pot.
  4. How to Repair a Cracked Flower Pot: paso 4, imagen 1 de 3 How to Repair a Cracked Flower Pot: paso 4, imagen 2 de 3 How to Repair a Cracked Flower Pot: paso 4, imagen 3 de 3
    • Scrape away the excess glue on both the outside and inside of the pot with scrap paper.
    • Make sure to do this before the glue dries completely.
  5. How to Repair a Cracked Flower Pot: paso 5, imagen 1 de 2 How to Repair a Cracked Flower Pot: paso 5, imagen 2 de 2
    • Use a shoelace or twine to tightly hold the pot together while it dries.
    • Depending on your glue, drying time may take up to 24-72 hours.
  6. How to Repair a Cracked Flower Pot: paso 6, imagen 1 de 3 How to Repair a Cracked Flower Pot: paso 6, imagen 2 de 3 How to Repair a Cracked Flower Pot: paso 6, imagen 3 de 3
    • Once your adhesive has finished drying, remove the shoelace or twine.
  7. How to Repair a Cracked Flower Pot: paso 7, imagen 1 de 2 How to Repair a Cracked Flower Pot: paso 7, imagen 2 de 2
    • Return your plant to its pot.
Conclusión
Now your flower pot is fixed and ready to be used!
Una persona más ha completado esta guía.
Irene Amuyunzu
Miembro Desde 10/26/18
148 Reputación
1 Guía escrita
Equipo
UC Davis, Team S1-G6, Bender Fall 2018 Miembro de UC Davis, Team S1-G6, Bender Fall 2018
UCD-BENDER-F18S1G6
3 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 42
Todo El Tiempo: 3,237
