Introducción
Skateboards can suffer damage such as scratches the more they are used and in certain circumstances, can sustain damage in the form of chipping. Chipping creates disproportions in the board that can be inconvenient to the owner. This guide can be used for any type of wooden board such as skateboards or long boards.
Qué necesitas
Unscrew the top screw from the deck using the Phillips #2 screwdriver while holding the corresponding nut on the truck.
Use the socket to remove the nuts on the trucks.
Once all the steps are done, you are ready to use your newly repaired board.
