Saltar al contenido principal
How to Repair a Burnt Wire for a Light Globe
Qué necesitas
  1. How to Repair a Burnt Wire for a Light Globe, How to Repair a Burnt Wire for a Light Globe: paso 1, imagen 1 de 2 How to Repair a Burnt Wire for a Light Globe, How to Repair a Burnt Wire for a Light Globe: paso 1, imagen 2 de 2
    • Use a flathead screwdriver to remove the two 3 mm screws from the power adapter.
  2. How to Repair a Burnt Wire for a Light Globe: paso 2, imagen 1 de 1
    • If needed, clean the power adapter's shell as much as possible.
  3. How to Repair a Burnt Wire for a Light Globe: paso 3, imagen 1 de 1
    • Use wire cutters to cut the wires to equal lengths.
  4. How to Repair a Burnt Wire for a Light Globe: paso 4, imagen 1 de 1
    • Use wire strippers to carefully peel the wire cord to expose 2 cm of wire.
  5. How to Repair a Burnt Wire for a Light Globe: paso 5, imagen 1 de 1
    • Slide the shell back into the wire cord, past the exposed copper wires.
  6. How to Repair a Burnt Wire for a Light Globe: paso 6, imagen 1 de 3 How to Repair a Burnt Wire for a Light Globe: paso 6, imagen 2 de 3 How to Repair a Burnt Wire for a Light Globe: paso 6, imagen 3 de 3
    • Grab the terminal of the power adapter and loosen the 3 mm screws of the terminal if needed.
    • Wrap one exposed copper wire around one loosened 3 mm screw and tighten the screw immediately.
    • Repeat the second bullet point for the second copper wire.
  7. How to Repair a Burnt Wire for a Light Globe: paso 7, imagen 1 de 2 How to Repair a Burnt Wire for a Light Globe: paso 7, imagen 2 de 2
    • Push the shell back into the terminal so that the terminal is protected by the shell.
    • Grab the 3 mm screws that were taken out in the first step and re-screw them into the shell.
  8. How to Repair a Burnt Wire for a Light Globe: paso 8, imagen 1 de 2 How to Repair a Burnt Wire for a Light Globe: paso 8, imagen 2 de 2
    • Plug in the power adapter into a functioning power outlet.
    • The light globe should now successfully turn on!
Linea de Meta
HarpreetGill
Miembro Desde 05/11/20
157 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 33
Todo El Tiempo: 500
