Saltar al contenido principal
How to Repair a Broken Slider on a Suitcase Zipper
Qué necesitas
  1. How to Repair a Broken Slider on a Suitcase Zipper, Slider on a Zipper: paso 1, imagen 1 de 1
    • Locate the zipper with the broken slider on the suitcase.
  2. How to Repair a Broken Slider on a Suitcase Zipper: paso 2, imagen 1 de 2 How to Repair a Broken Slider on a Suitcase Zipper: paso 2, imagen 2 de 2
    • Find the top of the zipper and locate the two stop pieces.
  3. How to Repair a Broken Slider on a Suitcase Zipper: paso 3, imagen 1 de 2 How to Repair a Broken Slider on a Suitcase Zipper: paso 3, imagen 2 de 2
    • Use your pliers to remove both of the stop pieces from the zipper.
    • Be careful to not tear the zipper fabric when removing the stop pieces.
  4. How to Repair a Broken Slider on a Suitcase Zipper: paso 4, imagen 1 de 3 How to Repair a Broken Slider on a Suitcase Zipper: paso 4, imagen 2 de 3 How to Repair a Broken Slider on a Suitcase Zipper: paso 4, imagen 3 de 3
    • Remove the original slider from the zipper.
  5. How to Repair a Broken Slider on a Suitcase Zipper: paso 5, imagen 1 de 2 How to Repair a Broken Slider on a Suitcase Zipper: paso 5, imagen 2 de 2
    • Attach the new slider to the zipper.
    • You may need to use some force to get the new zipper slider onto the zipper itself.
  6. How to Repair a Broken Slider on a Suitcase Zipper: paso 6, imagen 1 de 3 How to Repair a Broken Slider on a Suitcase Zipper: paso 6, imagen 2 de 3 How to Repair a Broken Slider on a Suitcase Zipper: paso 6, imagen 3 de 3
    • Attach two new stop pieces with a pair of pliers.
    • Use the pliers to crimp the stop pieces into the fabric.
    • The best area to place the stop pieces is directly above the first few teeth of the zipper.
  7. How to Repair a Broken Slider on a Suitcase Zipper: paso 7, imagen 1 de 2 How to Repair a Broken Slider on a Suitcase Zipper: paso 7, imagen 2 de 2
    • Check to make sure the zipper works by moving the slider up and down.
Linea de Meta
Demetria
Miembro Desde 03/07/19
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 65
Todo El Tiempo: 1,205
