Saltar al contenido principal
How to Repair a Broken Playhouse Door
Qué necesitas
  1. How to Repair a Broken Playhouse Door, How to Repair a Broken Playhouse Door: paso 1, imagen 1 de 1
    • Label each piece of wood with a number.
    • The door in this guide has seven panels, so I'll be labeling them 1 through 7.
  2. How to Repair a Broken Playhouse Door: paso 2, imagen 1 de 3 How to Repair a Broken Playhouse Door: paso 2, imagen 2 de 3 How to Repair a Broken Playhouse Door: paso 2, imagen 3 de 3
    • Use a Phillips screwdriver to remove all the screws so that each wood panel is separated.
  3. How to Repair a Broken Playhouse Door: paso 3, imagen 1 de 2 How to Repair a Broken Playhouse Door: paso 3, imagen 2 de 2
    • Gather all the individual wood panels and line them up in their numbered order so that the door looks complete.
  4. How to Repair a Broken Playhouse Door: paso 4, imagen 1 de 2 How to Repair a Broken Playhouse Door: paso 4, imagen 2 de 2
    • Apply wood glue to each panel of wood where it intersects with another piece.
    • You may want to keep a towel or napkin nearby to wipe off any excess glue.
  5. How to Repair a Broken Playhouse Door: paso 5, imagen 1 de 2 How to Repair a Broken Playhouse Door: paso 5, imagen 2 de 2
    • Attach clamps to the wood panels where the glue was applied. Place one clamp on each end.
    • It might be easiest to glue and clamp two wood panels together at a time and then attach all the pieces together once the glue dries.
    • Keep the clamps on the wood panels until the glue is completely dry. It takes about 24 hours for the glue to fully cure.
  6. How to Repair a Broken Playhouse Door: paso 6, imagen 1 de 3 How to Repair a Broken Playhouse Door: paso 6, imagen 2 de 3 How to Repair a Broken Playhouse Door: paso 6, imagen 3 de 3
    • After removing the clamps, use the Phillips screwdriver to put the screws back in the same spots they were removed from.
Linea de Meta
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 89
