Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Repair a Broken Necklace Clasp using a Fold-Over End Crimp with Loop
Qué necesitas
    1. How to Repair a Broken Necklace Clasp using a Fold-Over End Crimp with Loop, How to Repair a Broken Necklace Clasp using a Fold-Over End Crimp with Loop: paso 1, imagen 1 de 2 How to Repair a Broken Necklace Clasp using a Fold-Over End Crimp with Loop, How to Repair a Broken Necklace Clasp using a Fold-Over End Crimp with Loop: paso 1, imagen 2 de 2
      • Remove the outer wing of the old end crimp using pliers.
      • You can use any pliers, but diagonal cutting pliers work best for quick removal.
      Pregunta a FixBot
      Agregar Comentario
    2. How to Repair a Broken Necklace Clasp using a Fold-Over End Crimp with Loop: paso 2, imagen 1 de 2 How to Repair a Broken Necklace Clasp using a Fold-Over End Crimp with Loop: paso 2, imagen 2 de 2
      • Remove the inner wing of the old end crimp.
      Pregunta a FixBot
      Agregar Comentario
    3. How to Repair a Broken Necklace Clasp using a Fold-Over End Crimp with Loop: paso 3, imagen 1 de 2 How to Repair a Broken Necklace Clasp using a Fold-Over End Crimp with Loop: paso 3, imagen 2 de 2
      • Create a loop with the end of the necklace.
      • Place the loop against the inside of the new end crimp.
      • Adjust the placement of the end crimp as needed.
      Pregunta a FixBot
      Agregar Comentario
    4. How to Repair a Broken Necklace Clasp using a Fold-Over End Crimp with Loop: paso 4, imagen 1 de 2 How to Repair a Broken Necklace Clasp using a Fold-Over End Crimp with Loop: paso 4, imagen 2 de 2
      • Fold over one of the end crimp wings with nosed pliers.
      • Make sure the wing lays as flat as possible.
      • Avoid pinching yourself by keeping your fingers away from the plier hinges.
      Pregunta a FixBot
      Agregar Comentario
    5. How to Repair a Broken Necklace Clasp using a Fold-Over End Crimp with Loop: paso 5, imagen 1 de 2 How to Repair a Broken Necklace Clasp using a Fold-Over End Crimp with Loop: paso 5, imagen 2 de 2
      • Fold over the other crimp wing.
      Pregunta a FixBot
      Agregar Comentario
    6. How to Repair a Broken Necklace Clasp using a Fold-Over End Crimp with Loop: paso 6, imagen 1 de 1
      • Attach a jump ring to the end crimp's loop.
      Pregunta a FixBot
      Agregar Comentario
    7. How to Repair a Broken Necklace Clasp using a Fold-Over End Crimp with Loop: paso 7, imagen 1 de 1
      • Attach a necklace clasp to the same jump ring.
      Pregunta a FixBot
      Agregar Comentario
    8. How to Repair a Broken Necklace Clasp using a Fold-Over End Crimp with Loop: paso 8, imagen 1 de 2 How to Repair a Broken Necklace Clasp using a Fold-Over End Crimp with Loop: paso 8, imagen 2 de 2
      • Close the jump ring using pliers.
      Pregunta a FixBot
      Agregar Comentario
Linea de Meta
3 personas más completaron esta guía.
Joli LT
Miembro Desde 11/04/25
187 Reputación
1 Guía escrita
Equipo
UC Davis, Team 1-99, Serviss Fall 2025 Miembro de UC Davis, Team 1-99, Serviss Fall 2025
UCD-SERVISS-F25S1G99
Miembros de 4
11 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 17
Ultimos 30 días: 81
Todo El Tiempo: 408
