Saltar al contenido principal
How to Repair a Broken Kitchen Faucet Pull-out Spray Head
Qué necesitas
  1. How to Repair a Broken Kitchen Faucet Pull-out Spray Head, Kitchen Faucet Pull-out Spray Head: paso 1, imagen 1 de 2 How to Repair a Broken Kitchen Faucet Pull-out Spray Head, Kitchen Faucet Pull-out Spray Head: paso 1, imagen 2 de 2
    • Located underneath the sink is the water-control valve.
    • Shut off the water supply by turning the water-control valve.
    • Not all water control values are the same so some nozzles may vary.
  2. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: paso 2, imagen 1 de 3 How to Repair a Broken Kitchen Faucet Pull-out Spray Head: paso 2, imagen 2 de 3 How to Repair a Broken Kitchen Faucet Pull-out Spray Head: paso 2, imagen 3 de 3
    • Pull on the kitchen spray head nozzle to reveal the connected hose.
    • Unscrew the kitchen faucet spray head nozzle counterclockwise off of the hose assembly.
  3. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: paso 3, imagen 1 de 2 How to Repair a Broken Kitchen Faucet Pull-out Spray Head: paso 3, imagen 2 de 2
    • Remove the rubber gasket from the hose to reveal the c-clip.
    • Remove the c-clip that is located on the pull-out sprayer connection point with a small flat head screwdriver.
    • Do not discard the gasket. It can be reused unless damaged.
  4. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: paso 4, imagen 1 de 2 How to Repair a Broken Kitchen Faucet Pull-out Spray Head: paso 4, imagen 2 de 2
    • Pull on the sink faucet spray head from above the sink to find the main hose connection point to the water line located underneath the sink.
    • Unscrew the hose from the main faucet’s water line connection point.
    • A wrench may be necessary in order to loosen the nut.
    • Remove the hose from the sink sprayer location.
    • Connect the new hose by pressing it into the connection point. Then screw hose back on clockwise.
    • A wrench may be necessary in order to secure the end of the hose to the nut.
  5. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: paso 5, imagen 1 de 1
    • Apply plumber's tape to the male threads on the new sink sprayer head to avoid leakage.
Conclusión
2 personas más completaron esta guía.
Jodi Wright
Miembro Desde 02/23/16
158 Reputación
1 Guía escrita
Equipo
Texas Tech, Team 26-2, Rauch Spring 2016 Miembro de Texas Tech, Team 26-2, Rauch Spring 2016
TTU-RAUCH-S16S26G2
2 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 17
Ultimos 30 días: 71
Todo El Tiempo: 13,762
