Saltar al contenido principal
How to Repair a Broken Jump Ring
Qué necesitas
  1. How to Repair a Broken Jump Ring, How to Repair a Broken Jump Ring: paso 1, imagen 1 de 1
    • Firmly grasp the broken jump ring using one set of small needle-nose pliers.
    • Make sure that the ring's opening is not blocked by the pliers.
  2. How to Repair a Broken Jump Ring: paso 2, imagen 1 de 1
    • Grasp the opposite side of the jump ring with your other pair of small needle noise pliers.
  3. How to Repair a Broken Jump Ring: paso 3, imagen 1 de 1
    • Gently twist the pliers in opposite directions until the gap is wide enough to reattach the jump ring to the ear wire.
  4. How to Repair a Broken Jump Ring: paso 4, imagen 1 de 2 How to Repair a Broken Jump Ring: paso 4, imagen 2 de 2
    • Grasp the ear wire (if applicable) and insert its loop into the opening of the jump ring.
  5. How to Repair a Broken Jump Ring: paso 5, imagen 1 de 2 How to Repair a Broken Jump Ring: paso 5, imagen 2 de 2
    • Insert your earring into the opening of the jump ring.
  6. How to Repair a Broken Jump Ring: paso 6, imagen 1 de 2 How to Repair a Broken Jump Ring: paso 6, imagen 2 de 2
    • Grasp the jump ring between your two pairs of pliers and push/twist the two ends of the ring toward each other, until the two ends meet and the gap is closed.
    • Make sure that the gap is closed tight!
Conclusión
Your earrings are ready to be worn again!
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 34
Todo El Tiempo: 998
