Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Repair a Broken Huggie Earring Clasp
Qué necesitas
    1. How to Repair a Broken Huggie Earring Clasp, How to Repair a Broken Huggie Earring Clasp: paso 1, imagen 1 de 1
      • Clean the post and clasp of the earring with a dry cloth.
      Pregunta a FixBot
      Agregar Comentario
    2. How to Repair a Broken Huggie Earring Clasp: paso 2, imagen 1 de 2 How to Repair a Broken Huggie Earring Clasp: paso 2, imagen 2 de 2
      • Close the earring and note where the main post hits the notch on the opposite side.
      • There are two notches, one on the main post and one on the opposite side of the earring.
      Pregunta a FixBot
      Agregar Comentario
    3. How to Repair a Broken Huggie Earring Clasp: paso 3, imagen 1 de 1
      • Mark this spot with a writing instrument (optional).
      Pregunta a FixBot
      Agregar Comentario
    4. How to Repair a Broken Huggie Earring Clasp: paso 4, imagen 1 de 1
      • Re-open the earring.
      Pregunta a FixBot
      Agregar Comentario
    5. How to Repair a Broken Huggie Earring Clasp: paso 5, imagen 1 de 3 How to Repair a Broken Huggie Earring Clasp: paso 5, imagen 2 de 3 How to Repair a Broken Huggie Earring Clasp: paso 5, imagen 3 de 3
      • Ensure the post is lined up with the opposite notch. If not, gently bend it with your finger until it is in a suitable position.
      Pregunta a FixBot
      Agregar Comentario
    6. How to Repair a Broken Huggie Earring Clasp: paso 6, imagen 1 de 1
      • Grip the earring post with a small plier or tweezer and push the post slightly upward.
      Pregunta a FixBot
      Agregar Comentario
    7. How to Repair a Broken Huggie Earring Clasp: paso 7, imagen 1 de 2 How to Repair a Broken Huggie Earring Clasp: paso 7, imagen 2 de 2
      • Open to check if the earring clicks.
      Pregunta a FixBot
      Agregar Comentario
    8. How to Repair a Broken Huggie Earring Clasp: paso 8, imagen 1 de 1
      • If the earring isn’t clicking, push the post further upward using pliers.
      • Adjust, then check again.
      Pregunta a FixBot
      Agregar Comentario
    9. How to Repair a Broken Huggie Earring Clasp: paso 9, imagen 1 de 1
      • If the earring clicks but is hard to open, push the post downward using pliers.
      • This is an adjustment process, so make small adjustments until it is restored.
      Pregunta a FixBot
      Agregar Comentario
    10. How to Repair a Broken Huggie Earring Clasp: paso 10, imagen 1 de 1
      • Make final adjustments until the huggie clasp clicks and the earring closes securely.
      • Wipe the marker off of your earring.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Your earring is now fixed! If the post bends again, repeat the same steps to repair.
Hana Ito
Miembro Desde 04/26/24
181 Reputación
1 Guía escrita
Equipo
UC Davis, Team 4-6, Whithaus Spring 2024 Miembro de UC Davis, Team 4-6, Whithaus Spring 2024
UCD-WHITHAUS-S24S4G6
Miembros de 3
9 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 53
Todo El Tiempo: 662
