If you accidentally break your beautiful 3-wick candle and cannot burn it because the jar is heavily damaged. then this guide is for you. This guide will help you save money from buying a new candle and protect the environment from chemical reactions that candle wax causes in the landfill.
This guide requires you to use your stove to melt the candle (from Step 3 to Step 5). Use oven mitts or potholders to handle the cooking pot after it has been heated.
Place the wicks into glass jars, and secure the candle wicks by sticking the wick taps to bottom of the jars.
You should place your wicks in the middle of the glasses. An improperly centered wick will burn your candle unevenly later, and it is likely to leave soot on the side of the glass.
