Saltar al contenido principal
How to Repair a Bent Liquid Eyeliner Applicator
Qué necesitas
  1. How to Repair a Bent Liquid Eyeliner Applicator, How to Repair a Bent Liquid Eyeliner Applicator: paso 1, imagen 1 de 1
    • Remove the cap of the eyeliner.
  2. How to Repair a Bent Liquid Eyeliner Applicator: paso 2, imagen 1 de 3 How to Repair a Bent Liquid Eyeliner Applicator: paso 2, imagen 2 de 3 How to Repair a Bent Liquid Eyeliner Applicator: paso 2, imagen 3 de 3
    • Wrap the eyeliner applicator tightly with plastic wrap.
    • The plastic wrap should be just large enough to cover the applicator.
    • Smooth the bent bristles of the applicator in the same direction.
    • Smooth the excess plastic wrap along the body of the eyeliner.
  3. How to Repair a Bent Liquid Eyeliner Applicator: paso 3, imagen 1 de 1
    • Secure the plastic wrap tightly with a rubber band.
    • The rubber band should circle the middle of the applicator.
    • Check to make sure there are no holes in the plastic wrap.
  4. How to Repair a Bent Liquid Eyeliner Applicator: paso 4, imagen 1 de 1
    • Fill a pot with water.
    • The water level should be high enough to cover the tip of the eyeliner.
  5. How to Repair a Bent Liquid Eyeliner Applicator: paso 5, imagen 1 de 2 How to Repair a Bent Liquid Eyeliner Applicator: paso 5, imagen 2 de 2
    • Boil the water.
    • Turn off the heat once the water has reached a boil.
  6. How to Repair a Bent Liquid Eyeliner Applicator: paso 6, imagen 1 de 2 How to Repair a Bent Liquid Eyeliner Applicator: paso 6, imagen 2 de 2
    • Hold the eyeliner vertically above the pot of water. The applicator should be facing down.
    • Place the eyeliner applicator into the boiled water for 1 minute.
    • Do not submerge the eyeliner further than the applicator.
  7. How to Repair a Bent Liquid Eyeliner Applicator: paso 7, imagen 1 de 2 How to Repair a Bent Liquid Eyeliner Applicator: paso 7, imagen 2 de 2
    • Carefully remove the rubber band and the plastic wrap.
    • Great Job! Your eyeliner is ready to be used again.
Conclusión
This fix is a great alternative to throwing away eyeliner that still has plenty of pigment. You'll be saving money AND the environment. What could be better?
3 personas más completaron esta guía.
Tracy Sam
Miembro Desde 10/26/18
226 Reputación
1 Guía escrita
Equipo
UC Davis, Team S2-G4, Bender Fall 2018 Miembro de UC Davis, Team S2-G4, Bender Fall 2018
UCD-BENDER-F18S2G4
2 Miembros
1 Guía escrita
Un comentario
Saved me from going to the store for the old lady to get a new one. Thanks a $@$* load!!!!
jeremy loughran - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 85
Todo El Tiempo: 11,925
