Saltar al contenido principal
How to Repair a Bed Rail
Qué necesitas
  1. How to Repair a Bed Rail, How to Repair a Bed Rail: paso 1, imagen 1 de 1
    • Place an item(s) underneath the bed rail to support it. This can be bricks or books.
  2. How to Repair a Bed Rail: paso 2, imagen 1 de 1
    • Measure the length of the slat, and mark the middle.
    • This is the position where you will place the wooden plank and hammer in the nails.
  3. How to Repair a Bed Rail: paso 3, imagen 1 de 2 How to Repair a Bed Rail: paso 3, imagen 2 de 2
    • Vertically place your pre-cut wooden plank under the slat that is detached.
  4. How to Repair a Bed Rail: paso 4, imagen 1 de 1
    • Hammer the 50 mm nails down into the slat and into the wooden plank. You can use 2 or more to ensure the wooden plank is secure.
  5. How to Repair a Bed Rail: paso 5, imagen 1 de 1
    • Afterwards, run the glue along the detached bed rail.
  6. How to Repair a Bed Rail: paso 6, imagen 1 de 1
    • Reattach the bed rail and let the glue dry.
  7. How to Repair a Bed Rail: paso 7, imagen 1 de 1
    • After the glue has dried, remove your supports.
Conclusión
Endiyah Franklin
Miembro Desde 03/31/20
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 48
Todo El Tiempo: 2,198
