Introducción
A porch swing is a great addition to any outdoor space, but a backward tilt can make it uncomfortable and unsafe. Factors such as wear, improper installation, or environmental changes can lead to this issue. Fortunately, repairing a tilted swing is a manageable task that requires only a few basic tools.
This guide provides clear, step-by-step instructions on how to analyze the swing, adjust the chain links, and ensure that it hangs properly. By following these steps, you can restore your porch swing to a level position, making it safe and enjoyable once again.
Qué necesitas
(Before) Backward-Tilted Swing
Examine each side of the swing to determine the hook type used for hanging (ex., S-hook, eye bolt, screw carabiner hook, or other types).
Use a measuring tape to check and record the height of the swing from the ground to the armrest. Repeat this step on the other side.
Use a measuring tape to check and record the height of the swing from the ground to the top of the swing. Repeat this step on the other side.
Record these measurements to compare later.
(Optional) Place a level on the seat of the swing to check if it is level. Adjust the chains as needed until the bubble is centered.
Notice how the bubble is not centered to show the swing is level.
Use one pair of pliers to hold the S-hook steady.
Use the second pair of pliers to gently open the bottom side of the hook, allowing the chain links to slide off. This provides better leverage and stability.
Repeat this step to open the hook on the other side of the swing.
There should be a noticeable difference in the openings at the top and bottom of the hook.
Compare previous measurements to new measurements to ensure they are consistent on both sides. This is crucial to a level swing.
(Optional) Place a level on the armrest of the swing to check if it is level.
The bubbles are resting between the two lines, indicating that the swing is level.
(Optional) If there are still excess links, use bolt cutters to snip them off. Repeat this on both sides, if necessary.
Test your swing out by sitting in it. If the swing is still not in the desired position, repeat these steps to reposition it. Remember to check your swing regularly to keep it in good working condition!
