Saltar al contenido principal
How to Repair Wood Dents with Wood Filler
Qué necesitas
  1. How to Repair Wood Dents with Wood Filler, How to Repair Wood Dents with Wood Filler: paso 1, imagen 1 de 1
    • Inspect the damage in the wood and determine how much wood filler will be needed.
    • A shallow dent in the wood will require less wood filler than a dent with deeper damage.
  2. How to Repair Wood Dents with Wood Filler: paso 2, imagen 1 de 1
    • Smooth the surface where the damage was by scraping off the splinters using a 50 mm wide putty knife blade.
    • Use the corner of the blade to smooth over the bumps.
  3. How to Repair Wood Dents with Wood Filler: paso 3, imagen 1 de 1
    • Apply Elmer's Carpenter's Color Change Wood Filler to the putty knife and smear onto the surface.
    • An 8 ounce can of Elmer's Wood Filler will suffice for many repairs.
  4. How to Repair Wood Dents with Wood Filler: paso 4, imagen 1 de 1
    • Allow the filler to dry.
    • Shallow damages can take thirty minutes to an hour to dry.
    • Deep damages take up to two hours.
  5. How to Repair Wood Dents with Wood Filler: paso 5, imagen 1 de 1
    • Sand the dry surface using a 3M 75 mm wide fine-grit sandpaper.
    • Before sanding the surface, make sure the wood filler has dried by touching the wood filler.
  6. How to Repair Wood Dents with Wood Filler: paso 6, imagen 1 de 2 How to Repair Wood Dents with Wood Filler: paso 6, imagen 2 de 2
    • Apply Minwax Wood Finish Stain to the wood using a 25 mm stain brush.
    • Allow the stain to soak the surface for a few minutes so the wood absorbs it well.
    • An 8 ounce can of stain will suffice for this repair.
    • Optional: The 25 mm stain brush can be replaced with a regular 25 mm cloth brush found at home.
    • Multiple coats may be applied to reach the desired color.
  7. How to Repair Wood Dents with Wood Filler: paso 7, imagen 1 de 1
    • Optional: Paint the surface with white paint from a can of Rust-Oleum if the stain is not the desired color for the surface.
    • Use a 25 mm paint brush and an 8 ounce can of Rust-Oleum.
    • Multiple coats map be applied to reach the desired color.
  8. How to Repair Wood Dents with Wood Filler: paso 8, imagen 1 de 1
    • Dry the surface by patting the surface with a cloth towel.
Conclusión
If the damage is still visible, then follow steps 1 through 8 again until the damaged area matches the rest of the wood. I hope this guide was helpful!
Nicole See
Miembro Desde 01/16/17
161 Reputación
1 Guía escrita
Equipo
Un comentario
Thank you for sharing this post
تعمیرات مبل کسری - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 36
Todo El Tiempo: 6,085
