Saltar al contenido principal
How to Repair Wall Texture
Qué necesitas
  1. How to Repair Wall Texture, How to Repair Wall Texture: paso 1, imagen 1 de 1
    • First, Inspect and clean the location that needs repair.
  2. How to Repair Wall Texture: paso 2, imagen 1 de 1
    • Clean up the edges with a box cutter.
  3. How to Repair Wall Texture: paso 3, imagen 1 de 1
    • Apply a single sided mesh tape used for patch work to increase the strength of the material.
  4. How to Repair Wall Texture: paso 4, imagen 1 de 2 How to Repair Wall Texture: paso 4, imagen 2 de 2
    • Apply spackling paste over the mesh tape to fill the hole.
  5. How to Repair Wall Texture: paso 5, imagen 1 de 2 How to Repair Wall Texture: paso 5, imagen 2 de 2
    • Let the spackling paste sit and dry.
    • The quick dry spackling paste will change colors from a pink to a white indicating that the paste has dried.
  6. How to Repair Wall Texture: paso 6, imagen 1 de 1
    • Sand the rough edges of the spackling paste to smooth the surfaces until it is flush with the wall.
  7. How to Repair Wall Texture: paso 7, imagen 1 de 1
    • Spray aerosol wall texture over the leveled patch in a quick fluid motion from one side to another.
  8. How to Repair Wall Texture: paso 8, imagen 1 de 1
    • Let the texture dry overnight.
    • Paint the wall with your desired color to complete the wall texturing repair.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 25
Todo El Tiempo: 2,332
