Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Repair Trim On a Decorative Towel
Qué necesitas
  1. How to Repair Trim On a Decorative Towel, How to Repair Trim On a Decorative Towel: paso 1, imagen 1 de 1
    • Choose a thread the same colour as the towel.
    • Use sewing scissors to cut a piece of thread about 18 inches long.
  2. How to Repair Trim On a Decorative Towel: paso 2, imagen 1 de 1
    • Thread the string through the needle.
    • Tie a knot at the longest end of the thread.
  3. How to Repair Trim On a Decorative Towel: paso 3, imagen 1 de 2 How to Repair Trim On a Decorative Towel: paso 3, imagen 2 de 2
    • Flip your towel over so the backside of the towel is facing up.
  4. How to Repair Trim On a Decorative Towel: paso 4, imagen 1 de 2 How to Repair Trim On a Decorative Towel: paso 4, imagen 2 de 2
    • Starting at one side of the rip, insert the needle through the trim and then the towel.
    • Pull the thread through until it stops at the knot.
  5. How to Repair Trim On a Decorative Towel: paso 5, imagen 1 de 2 How to Repair Trim On a Decorative Towel: paso 5, imagen 2 de 2
    • Flip the towel over so the front side is facing up.
    • Insert the needle through the towel, then the trim.
    • Pull the thread through.
  6. How to Repair Trim On a Decorative Towel: paso 6, imagen 1 de 2 How to Repair Trim On a Decorative Towel: paso 6, imagen 2 de 2
    • Repeat steps 4 and 5 until you reach the end of the trim.
  7. How to Repair Trim On a Decorative Towel: paso 7, imagen 1 de 3 How to Repair Trim On a Decorative Towel: paso 7, imagen 2 de 3 How to Repair Trim On a Decorative Towel: paso 7, imagen 3 de 3
    • Insert the needle through the back of the towel.
    • Pull the string through with enough length to create a small loop.
    • Put the needle through the loop and pull the string to tie a knot.
  8. How to Repair Trim On a Decorative Towel: paso 8, imagen 1 de 2 How to Repair Trim On a Decorative Towel: paso 8, imagen 2 de 2
    • Remove the needle.
    • Use your sewing scissors to cut the remaining thread.
Conclusión
Victoria Torkos
Miembro Desde 09/19/22
157 Reputación
1 Guía escrita
Equipo
York University, Team A-3, Morris Fall 2022 Miembro de York University, Team A-3, Morris Fall 2022
YORK-MORRIS-F22SAG3
Miembros de 3
2 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 18
Todo El Tiempo: 473
