Saltar al contenido principal
How to Repair Scratches in Laminate Finish Furniture
Qué necesitas
  1. How to Repair Scratches in Laminate Finish Furniture, How to Repair Scratches in Laminate Finish Furniture: paso 1, imagen 1 de 1
    • Clean the scratched area with a damp cloth or paper towel to remove any dust or debris.
  2. How to Repair Scratches in Laminate Finish Furniture: paso 2, imagen 1 de 1
    • Apply a small amount of wood filler to a putty knife.
    • The amount of wood filler needed may vary depending on severity of the scratches.
  3. How to Repair Scratches in Laminate Finish Furniture: paso 3, imagen 1 de 1
    • Spread the wood filler over the scratches using the putty knife until they are sufficiently filled in.
    • The putty knife can be used to scrape away excess wood filler and smooth the surface.
  4. How to Repair Scratches in Laminate Finish Furniture: paso 4, imagen 1 de 1
    • Wipe away any residual wood filler from the surface using a damp cloth or paper towel.
  5. How to Repair Scratches in Laminate Finish Furniture: paso 5, imagen 1 de 1
    • Allow the wood filler to dry completely based on the package instructions before resuming use.
  6. How to Repair Scratches in Laminate Finish Furniture: paso 6, imagen 1 de 1
    • Sand over the wood filler using fine-grit sandpaper if a smoother finish is desired.
  7. How to Repair Scratches in Laminate Finish Furniture: paso 7, imagen 1 de 1
    • Paint over the wood filler, if desired, to color match the filler with the furniture.
    • Wood filler comes in a variety of colors so painting may not be necessary.
Linea de Meta
Shelby
Miembro Desde 02/20/24
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 8
Ultimos 30 días: 24
Todo El Tiempo: 45
