Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Repair Hook Earrings
Qué necesitas
    1. How to Repair Hook Earrings, How to Repair Hook Earrings: paso 1, imagen 1 de 3 How to Repair Hook Earrings, How to Repair Hook Earrings: paso 1, imagen 2 de 3 How to Repair Hook Earrings, How to Repair Hook Earrings: paso 1, imagen 3 de 3
      • Clean both the hook and earring with hydrogen peroxide to ensure that there are no germs, dust, or other particles on the pieces.
      Pregunta a FixBot
      Agregar Comentario
    2. How to Repair Hook Earrings: paso 2, imagen 1 de 3 How to Repair Hook Earrings: paso 2, imagen 2 de 3 How to Repair Hook Earrings: paso 2, imagen 3 de 3
      • In one hand, hold the hook in place.
      • Use pliers to gently pull open the small loop at the base of the hook.
      Pregunta a FixBot
      Agregar Comentario
    3. How to Repair Hook Earrings: paso 3, imagen 1 de 3 How to Repair Hook Earrings: paso 3, imagen 2 de 3 How to Repair Hook Earrings: paso 3, imagen 3 de 3
      • Carefully insert the open loop on the hook through the loop on the earring.
      • If your earring has a designated front and back, ensure that the front of the earring is facing away from the tip of the hook.
      Pregunta a FixBot
      Agregar Comentario
    4. How to Repair Hook Earrings: paso 4, imagen 1 de 2 How to Repair Hook Earrings: paso 4, imagen 2 de 2
      • Use pliers to close the loop by clamping down on the open end of the loop and the base of the hook, pushing them towards one another.
      • If done correctly, the loop should be a complete circle.
      Pregunta a FixBot
      Agregar Comentario
    5. How to Repair Hook Earrings: paso 5, imagen 1 de 1
      • Rotate the loop so that the pliers are touching both sides of the completed circle.
      • Gently clamp down.
      • This step ensures that the loop is completely closed with no gaps.
      Pregunta a FixBot
      Agregar Comentario
    6. How to Repair Hook Earrings: paso 6, imagen 1 de 1
      • You're done! Congratulations on repairing your hook earrings!
      Pregunta a FixBot
      Agregar Comentario
Conclusión
To reassemble your earring properly, please complete these instructions in numerical order. Earrings can be extremely delicate, so make sure you are being gentle in each step. If you accidentally reattach the earring backwards, simply go back to step two and reopen the loop. If followed correctly, you will officially know how to reattach a hook to an earring!
Anna
Miembro Desde 03/21/22
183 Reputación
1 Guía escrita
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 46
Todo El Tiempo: 756
