Saltar al contenido principal
How to Repair Frayed Shoelaces
Qué necesitas
  1. How to Repair Frayed Shoelaces, How to Repair Frayed Shoelaces: paso 1, imagen 1 de 1
    • Cut of the excess frayed shoelace.
  2. How to Repair Frayed Shoelaces: paso 2, imagen 1 de 3 How to Repair Frayed Shoelaces: paso 2, imagen 2 de 3 How to Repair Frayed Shoelaces: paso 2, imagen 3 de 3
    • Slip the entire heat shrink tube over the frayed part of the lace.
    • Make sure to clump the frayed part of the lace together when inserting the tubing.
    • Do not cover too much of the lace that is not frayed with tubing as that could result in unwanted indents in the shoelace.
  3. How to Repair Frayed Shoelaces: paso 3, imagen 1 de 2 How to Repair Frayed Shoelaces: paso 3, imagen 2 de 2
    • After slipping the tube on, grab the scissors and trim the excess tubing to the length of your satisfaction.
    • Remember not to go beyond the frayed part of the lace with tubing.
  4. How to Repair Frayed Shoelaces: paso 4, imagen 1 de 3 How to Repair Frayed Shoelaces: paso 4, imagen 2 de 3 How to Repair Frayed Shoelaces: paso 4, imagen 3 de 3
    • Now use the lighter and heat the heat shrink tube, about an inch away from the lace, until the tube becomes compressed all the way around.
    • Make sure to heat the heat shrink tube all the way around, heating the entire tube
    • When heating, always keep moving the lighter all around and not staying on one part of the tube for too long.
  5. How to Repair Frayed Shoelaces: paso 5, imagen 1 de 1
    • Repeat these steps on all the other frayed shoelaces.
Conclusión
When the heat shrink tube is completely shrunk to appropriate size, you are finished. Repeat steps 1-4 depending on how many frayed laces are present.
14 personas más completaron esta guía.
Anirudh Jain
Miembro Desde 04/09/15
605 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 28-6, Green Spring 2015 Miembro de Cal Poly, Team 28-6, Green Spring 2015
CPSU-GREEN-S15S28G6
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 19
Ultimos 30 días: 62
Todo El Tiempo: 11,752
