Saltar al contenido principal
How to Repair Corners of Drywall
Qué necesitas
  1. How to Repair Corners of Drywall, How to Repair Corners of Drywall: paso 1, imagen 1 de 3 How to Repair Corners of Drywall, How to Repair Corners of Drywall: paso 1, imagen 2 de 3 How to Repair Corners of Drywall, How to Repair Corners of Drywall: paso 1, imagen 3 de 3
    • Measure top and bottom of damaged section.
    • When replacing a corner bead, you must measure at least 1.5 inches from the corner.
    • Use a straight edge between the the top and bottom and draw a straight-line connecting the marking.
    • You can even use the putty knife if the damaged section is not too long.
    • Mark with a pencil, or cut lightly with utility knife.
    • Use caution when using the utility knife as the blade is very sharp and may cause an injury.
  2. How to Repair Corners of Drywall: paso 2, imagen 1 de 2 How to Repair Corners of Drywall: paso 2, imagen 2 de 2
    • Using your putty knife, dig out of the spackle inside your marking.
    • You need to get down to the metal, or vinyl corner drywall bead.
    • Use caution to not dig too deep.
  3. How to Repair Corners of Drywall: paso 3, imagen 1 de 1
    • Unscrew screws in the section of bead that you are going to remove.
    • If it is a vinyl corner bead, then break taped underside with corner of putty knife carefully.
    • Cut the metal corner bead with tin snips.
    • If Vinyl, then use your utility knife.
    • Measure new corner bead and cut.
    • Place new corner bead on corner and fasten in place using screws or tape.
  4. How to Repair Corners of Drywall: paso 4, imagen 1 de 1
    • Apply joint compound with a 4 inch putty knife.
    • The more compound the better. It will shrink while drying.
    • Do not worry about getting corners the perfect.
    • Dry for 12 hours.
  5. How to Repair Corners of Drywall: paso 5, imagen 1 de 3 How to Repair Corners of Drywall: paso 5, imagen 2 de 3 How to Repair Corners of Drywall: paso 5, imagen 3 de 3
    • Sand area with 80 grit sandpaper.
    • Wipe down with damp cloth, sponge, or paper towel.
    • Be careful to not wet down the patch with too much water. Only minimum amount of dampness needed to wipe away sanding dust.
    • Apply thinner coat of joint compound with a 6, or 8 inch putty knife.
    • Pay attention to put pressure on the outside edge.
    • Let dry for 2 hours.
  6. How to Repair Corners of Drywall: paso 6, imagen 1 de 1
    • Sand the area with 120 grit sandpaper.
    • If needed, repeat Step 5 again.
    • Paint the patched area to match wall
Conclusión
Now the corner drywall is ready to be painted and match the rest of the room.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 23
Ultimos 30 días: 96
Todo El Tiempo: 20,274
