Saltar al contenido principal
How to Repair A Wet Book
Qué necesitas
  1. How to Repair A Wet Book, How to Repair A Wet Book: paso 1, imagen 1 de 1
    • Be cautious when handling wet books, as books are very fragile when wet and you can accidentally damage front cover, pages, and/or spine.
    • If you do not have time to fix it, immediately put it in a Ziplock bag and place in freezer until you're ready. When you are ready to fix it, lay it on the table and leave it until it thaws.
    • Cover table with plastic sheet or newspapers.
  2. How to Repair A Wet Book: paso 2, imagen 1 de 1
    • Lay the book down with the front cover facing up. Place a paper towel over the cover and gently press down on the book.
  3. How to Repair A Wet Book: paso 3, imagen 1 de 2 How to Repair A Wet Book: paso 3, imagen 2 de 2
    • Be very careful when opening the book, as the spine is very fragile.
    • Gently opening the book to a shallow angle, place paper towels every 10-20 pages in the front half of the book. Place a paper towel on the front cover and press down gently.
  4. How to Repair A Wet Book: paso 4, imagen 1 de 2 How to Repair A Wet Book: paso 4, imagen 2 de 2
    • Similarly to step 3, gently open the book to a shallow angle and place paper towels in every 10-20 pages towards the last half of the book. Place a paper towel on the front cover and press down.
  5. How to Repair A Wet Book: paso 5, imagen 1 de 1
    • Stand the book up, heads or tails, with the pages fanned out.
  6. How to Repair A Wet Book: paso 6, imagen 1 de 1
    • To speed up the drying process, leave a fan blowing on it.
  7. How to Repair A Wet Book: paso 7, imagen 1 de 2 How to Repair A Wet Book: paso 7, imagen 2 de 2
    • If after the book has dried the pages are wavy, lay the book flat and place a board on top of it, along with a couple of heavy books (on top of the board) to help flatten them out. Leave it like this until the pages are completely flattened.
  8. How to Repair A Wet Book: paso 8, imagen 1 de 1
    • Great job! The book is now restored to its original condition. Happy reading!
Linea de Meta
Una persona más ha completado esta guía.
2 comentarios
because im in middle school. and it is sters full with wet books
Hazen Harwood - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 49
Todo El Tiempo: 1,035
