Saltar al contenido principal
How to Repair A Broken Hip In A Plastic Doll
Qué necesitas
  1. How to Repair A Broken Hip In A Plastic Doll, How to Repair A Broken Hip In A Plastic Doll: paso 1, imagen 1 de 2 How to Repair A Broken Hip In A Plastic Doll, How to Repair A Broken Hip In A Plastic Doll: paso 1, imagen 2 de 2
    • Determine where your doll is broken: is it at the knee? Hip? Arm?
    • If it’s broken at the knee, as marked in the second photo, unfortunately this guide will not help as it is a different kind of joint.
  2. How to Repair A Broken Hip In A Plastic Doll: paso 2, imagen 1 de 2 How to Repair A Broken Hip In A Plastic Doll: paso 2, imagen 2 de 2
    • If the ball is still inside the leg, remove it with pliers.
  3. How to Repair A Broken Hip In A Plastic Doll: paso 3, imagen 1 de 1
    • Hold one of the sewing pins with the pliers and heat the sewing pin with a lighter.
    • Do not leave fire unattended. The metal will be hot, so please don't touch it with your bare skin.
  4. How to Repair A Broken Hip In A Plastic Doll: paso 4, imagen 1 de 1
    • With the hot sewing needle, make a small hole in the center of the broken off ball. Make sure the needle is straight.
    • This may take a few attempts and a few needles.
    • Heating up the plastic will result in some fumes. Perform this step in a well ventilated area.
  5. How to Repair A Broken Hip In A Plastic Doll: paso 5, imagen 1 de 1
    • Hold one of the sewing pins with the pliers and heat the sewing pin with a lighter. (This is a repeat of Step 3.)
  6. How to Repair A Broken Hip In A Plastic Doll: paso 6, imagen 1 de 2 How to Repair A Broken Hip In A Plastic Doll: paso 6, imagen 2 de 2
    • With the hot sewing needle, make a small hole in the peg of the hip. Make sure the needle is straight. Leave the pin inside.
  7. How to Repair A Broken Hip In A Plastic Doll: paso 7, imagen 1 de 2 How to Repair A Broken Hip In A Plastic Doll: paso 7, imagen 2 de 2
    • Remove the pin from the broken off ball joint with a pair of pliers.
  8. How to Repair A Broken Hip In A Plastic Doll: paso 8, imagen 1 de 2 How to Repair A Broken Hip In A Plastic Doll: paso 8, imagen 2 de 2
    • Using the pliers, cut the pin in the hip section to the appropriate length to fit into the hole made from Step 6.
    • Test the needle length by fitting the ball joint pieces together. The needle should be completely covered.
    • The needle will go flying when you cut it, so direct it away from your face and other precious objects.
  9. How to Repair A Broken Hip In A Plastic Doll: paso 9, imagen 1 de 1
    • Optional: remove any excess burnt plastic from the ball joint.
  10. How to Repair A Broken Hip In A Plastic Doll: paso 10, imagen 1 de 3 How to Repair A Broken Hip In A Plastic Doll: paso 10, imagen 2 de 3 How to Repair A Broken Hip In A Plastic Doll: paso 10, imagen 3 de 3
    • Remove the pin from the hip and apply super glue to the end.
    • Insert the pin back into the hole.
    • When you reinsert the pin, some glue may come out. Leave it for Step 11.
  11. How to Repair A Broken Hip In A Plastic Doll: paso 11, imagen 1 de 1
    • Push the ball onto the pin. Press together for 1 minute to set the glue.
    • The glue will set in 1 minute but it will take 24 hours to fully cure.
  12. How to Repair A Broken Hip In A Plastic Doll: paso 12, imagen 1 de 1
    • Apply glue around the seam for extra reinforcement.
  13. How to Repair A Broken Hip In A Plastic Doll: paso 13, imagen 1 de 2 How to Repair A Broken Hip In A Plastic Doll: paso 13, imagen 2 de 2
    • Now with the ball joint secured into the pelvis, carefully pop the leg back into the hip.
    • The doll's leg should now move as normal!
Conclusión
To reassemble your device, follow these instructions in order.
2 personas más completaron esta guía.
Lee Brunkhardt
Miembro Desde 01/31/23
232 Reputación
1 Guía escrita
Equipo
UC Davis, Team 3-1, Andersen Winter 2023 Miembro de UC Davis, Team 3-1, Andersen Winter 2023
UCD-ANDERSEN-W23S3G1
5 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 17
Ultimos 30 días: 113
Todo El Tiempo: 1,572
