Saltar al contenido principal
How to Repaint Your Garage Floor
Qué necesitas
  1. How to Repaint Your Garage Floor, How to Repaint Your Garage Floor: paso 1, imagen 1 de 1
    • Use a paint scraper to remove the old paint from the area where you want to apply the new paint.
    • It's okay if there is still some old paint left on the surface.
    • Paint cracks usually indicate corrosion and require scraping.
  2. How to Repaint Your Garage Floor: paso 2, imagen 1 de 1
    • Remove debris and dust with a broom.
  3. How to Repaint Your Garage Floor: paso 3, imagen 1 de 1
    • Examine the quality of your paint.
    • If it is too thick, and you're using water-based paint, mix in a little bit of water.
    • If it is too thick, and you're using an oil-based paint, add paint thinner.
  4. How to Repaint Your Garage Floor: paso 4, imagen 1 de 1
    • Wet the surface of the roller with water.
  5. How to Repaint Your Garage Floor: paso 5, imagen 1 de 2 How to Repaint Your Garage Floor: paso 5, imagen 2 de 2
    • Pour the paint in a container, dip your roller in, and start rolling.
    • You can also use a paint brush.
  6. How to Repaint Your Garage Floor: paso 6, imagen 1 de 1
    • New paint has been applied and you can see the direct contrast.
    • When the paint has dried, reapply a second coat of paint.
  7. How to Repaint Your Garage Floor: paso 7, imagen 1 de 1
    • Collect all the tools and prepare them for cleaning.
    • For water-based paint, rinse the tools in water. For oil-based paint, rinse the tools in paint thinner.
    • When rinsing, don't dip your tools in your paint thinner container directly. Instead, pour the paint thinner into another container that can be used for rinsing the tools.
Conclusión
Follow these instructions so you can be the next person to learn how to paint.
Una persona más ha completado esta guía.
Chao Zheng
Miembro Desde 09/20/20
177 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 30
Todo El Tiempo: 708
