Saltar al contenido principal
How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter
Qué necesitas
  1. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter, Air Filter: paso 1, imagen 1 de 2 How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter, Air Filter: paso 1, imagen 2 de 2
    • Make sure that the motor is off and has had time to cool after being used.
    • Push in the clips on the top of the cover, and remove the cover.
  2. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: paso 2, imagen 1 de 1
    • Make a note of the position of the filter, and remove the cover.
  3. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: paso 3, imagen 1 de 1
    • Lightly bend the filter so that you can see all surfaces of the filter.
  4. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: paso 4, imagen 1 de 1
    • Use compressed air to blow out dirt or dust particles from the air filter.
    • You can bend it in several places to make sure you clean between each of the fins.
  5. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: paso 5, imagen 1 de 1
    • Seat the filter in the same position you made a note of in Step 2.
    • If the filter is still bent from cleaning it, lightly bend it in the opposite direction so that it can lay flat in your hand.
    • Place the cover onto the air filter. This shouldn't require any force, so the filter may need to be readjusted if it does require force.
  6. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: paso 6, imagen 1 de 2 How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: paso 6, imagen 2 de 2
    • Push the clips of the cover in until they click.
    • Check to make sure that the cover is secure, and there are no gaps for dirt or dust to get in.
Linea de Meta
Una persona más ha completado esta guía.
Pearce McKee
Miembro Desde 03/31/20
133 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 20
Ultimos 30 días: 50
Todo El Tiempo: 1,299
