Saltar al contenido principal
How to Remove a Broken and Embedded Screw
Qué necesitas
  1. How to Remove a Broken and Embedded Screw, How to Remove a Broken and Embedded Screw: paso 1, imagen 1 de 1
    • Use an angle grinder to grind the tip of the broken screw until its surface is smooth and even.
  2. How to Remove a Broken and Embedded Screw: paso 2, imagen 1 de 2 How to Remove a Broken and Embedded Screw: paso 2, imagen 2 de 2
    • Place a center punch in the middle of the tip of the screw.
    • Use a hammer to hit the center punch to make a dent in the center of the embedded screw.
  3. How to Remove a Broken and Embedded Screw: paso 3, imagen 1 de 3 How to Remove a Broken and Embedded Screw: paso 3, imagen 2 de 3 How to Remove a Broken and Embedded Screw: paso 3, imagen 3 de 3
    • Place a center drill bit in the dent made in the previous step and start drilling until it expands enough to fit the standard drill bit inside it.
    • Always keep the drill bit at a 90 degree angle to the surface of the screw since tilting it can bend and break its tip.
  4. How to Remove a Broken and Embedded Screw: paso 4, imagen 1 de 3 How to Remove a Broken and Embedded Screw: paso 4, imagen 2 de 3 How to Remove a Broken and Embedded Screw: paso 4, imagen 3 de 3
    • Make a hole in the tip of the screw by drilling with a standard drill bit.
    • Keep drilling until the hole reaches near the end of the screw.
  5. How to Remove a Broken and Embedded Screw: paso 5, imagen 1 de 2 How to Remove a Broken and Embedded Screw: paso 5, imagen 2 de 2
    • Insert a screw extractor in the hole and then hammer it inside, making sure it is tight.
  6. How to Remove a Broken and Embedded Screw: paso 6, imagen 1 de 3 How to Remove a Broken and Embedded Screw: paso 6, imagen 2 de 3 How to Remove a Broken and Embedded Screw: paso 6, imagen 3 de 3
    • Using a wrench, unscrew the extractor.
    • The screw will come along with it, freeing the hole.
  7. How to Remove a Broken and Embedded Screw: paso 7, imagen 1 de 2 How to Remove a Broken and Embedded Screw: paso 7, imagen 2 de 2
    • Screw the new screw inside the freed hole.
Linea de Meta
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 121
Ultimos 30 días: 447
Todo El Tiempo: 6,543
