Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Remove a Blood Stain from Satin
Qué necesitas
  1. How to Remove a Blood Stain from Satin, How to Remove a Blood Stain from Satin: paso 1, imagen 1 de 2 How to Remove a Blood Stain from Satin, How to Remove a Blood Stain from Satin: paso 1, imagen 2 de 2
    • Dip the stained fabric in bowl of cold water.
    • Massage the stain while submerged for about 20 seconds to ensure that it is fully saturated.
  2. How to Remove a Blood Stain from Satin: paso 2, imagen 1 de 1
    • Pour laundry detergent or dish soap into bowl.
    • Amount poured should equate to approximately 1/2 cup (120ml). Larger stains may require higher quantities.
  3. How to Remove a Blood Stain from Satin: paso 3, imagen 1 de 2 How to Remove a Blood Stain from Satin: paso 3, imagen 2 de 2
    • Wet a clean, dry cloth or sponge in the bowl.
  4. How to Remove a Blood Stain from Satin: paso 4, imagen 1 de 2 How to Remove a Blood Stain from Satin: paso 4, imagen 2 de 2
    • Dab the stain gently by repeatedly pressing the wet cloth or sponge against it.
    • Rubbing the stain may further spread it and/or embed it deeper in the fabric.
  5. How to Remove a Blood Stain from Satin: paso 5, imagen 1 de 2 How to Remove a Blood Stain from Satin: paso 5, imagen 2 de 2
    • Rinse the stain with cold water.
    • Inspect to determine whether further cleaning is required.
  6. How to Remove a Blood Stain from Satin: paso 6, imagen 1 de 1
    • Add a few drops of vinegar or hydrogen peroxide to the initial solution if the stain persists.
    • Repeat steps 3 and 4.
    • The combination of these chemicals creates peracetic acid. Do not mix hydrogen peroxide and vinegar.
  7. How to Remove a Blood Stain from Satin: paso 7, imagen 1 de 1
    • Rinse the garment in a bowl of clean water.
Conclusión
Repeat as needed until the stain is gone.
Malak Elsayed Elghobashy
Miembro Desde 02/06/25
145 Reputación
1 Guía escrita
Equipo
York University, Team 1-1, Morris Winter 2025 Miembro de York University, Team 1-1, Morris Winter 2025
YORK-MORRIS-W25S1G1
Miembros de 5
2 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 53
Ultimos 30 días: 192
Todo El Tiempo: 1,187
