Saltar al contenido principal
How to Remove Rust on Car Body
Qué necesitas
  1. How to Remove Rust on Car Body, How to Remove Rust on Car Body: paso 1, imagen 1 de 2 How to Remove Rust on Car Body, How to Remove Rust on Car Body: paso 1, imagen 2 de 2
    • Spray down the rust with a spray bottle mixed with water and dish soap.
    • Wipe the mixture with a microfiber cloth.
  2. How to Remove Rust on Car Body: paso 2, imagen 1 de 3 How to Remove Rust on Car Body: paso 2, imagen 2 de 3 How to Remove Rust on Car Body: paso 2, imagen 3 de 3
    • Pour a small amount of rubbing alcohol onto a microfiber cloth.
    • Clean the rusted area with the cloth to remove any contaminants.
  3. How to Remove Rust on Car Body: paso 3, imagen 1 de 3 How to Remove Rust on Car Body: paso 3, imagen 2 de 3 How to Remove Rust on Car Body: paso 3, imagen 3 de 3
    • Rub the rusted area with 80-grit sandpaper until you start seeing the bare metal.
  4. How to Remove Rust on Car Body: paso 4, imagen 1 de 2 How to Remove Rust on Car Body: paso 4, imagen 2 de 2
    • Rub the rusted area with 220-grit sandpaper until all of the rust is removed.
    • Dampen a cloth with soapy water and wipe down the sanded area.
  5. How to Remove Rust on Car Body: paso 5, imagen 1 de 2 How to Remove Rust on Car Body: paso 5, imagen 2 de 2
    • This step is to prepare your spot for spray painting.
    • Add some paper around the areas you do not want paint on. Make sure you go a little past where you are going to spray paint to blend the paint into the surrounding area.
  6. How to Remove Rust on Car Body: paso 6, imagen 1 de 3 How to Remove Rust on Car Body: paso 6, imagen 2 de 3 How to Remove Rust on Car Body: paso 6, imagen 3 de 3
    • Spray three even coats of primer, waiting at least five minutes between each coat.
    • Let the third coat sit for 15 minutes.
  7. How to Remove Rust on Car Body: paso 7, imagen 1 de 3 How to Remove Rust on Car Body: paso 7, imagen 2 de 3 How to Remove Rust on Car Body: paso 7, imagen 3 de 3
    • Spray three even coats of paint on top of the primer, waiting five minutes between each coat.
    • You can either use a color similar to your car or you can get the actual color of you car by looking for the car's color code.
    • After the final coat, wait 24 hours before removing the surrounding paper.
Linea de Meta
Una persona más ha completado esta guía.
Robert Gutierrez
Miembro Desde 08/25/22
163 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 19
Ultimos 30 días: 116
Todo El Tiempo: 1,807
