Saltar al contenido principal
How to Remove Rust from the Nipper D-108
Qué necesitas
  1. How to Remove Rust from the Nipper D-108, How to Remove Rust from the Nipper D-108: paso 1, imagen 1 de 3 How to Remove Rust from the Nipper D-108, How to Remove Rust from the Nipper D-108: paso 1, imagen 2 de 3 How to Remove Rust from the Nipper D-108, How to Remove Rust from the Nipper D-108: paso 1, imagen 3 de 3
    • Take out a medium bowl.
    • Put on a pair of nitrile gloves.
  2. How to Remove Rust from the Nipper D-108: paso 2, imagen 1 de 3 How to Remove Rust from the Nipper D-108: paso 2, imagen 2 de 3 How to Remove Rust from the Nipper D-108: paso 2, imagen 3 de 3
    • Pour about 3-4 tablespoons of baking soda into the bowl.
    • Pour enough white vinegar into the bowl to cover the nipper.
    • Mix baking soda and white vinegar together.
  3. How to Remove Rust from the Nipper D-108: paso 3, imagen 1 de 2 How to Remove Rust from the Nipper D-108: paso 3, imagen 2 de 2
    • Put the nipper in the mixture and soak for about an hour.
  4. How to Remove Rust from the Nipper D-108: paso 4, imagen 1 de 3 How to Remove Rust from the Nipper D-108: paso 4, imagen 2 de 3 How to Remove Rust from the Nipper D-108: paso 4, imagen 3 de 3
    • Take a toothbrush and dip it in the mixture of vinegar and baking soda.
    • Scrub the rusty areas of the nipper until it is clean.
  5. How to Remove Rust from the Nipper D-108: paso 5, imagen 1 de 1
    • Wash the nipper with water.
  6. How to Remove Rust from the Nipper D-108: paso 6, imagen 1 de 1
    • Use a towel to wipe the nipper dry.
Conclusión
Vi Phan
Miembro Desde 07/03/22
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 45
Todo El Tiempo: 1,227
