Introducción
If you need to access laptop internals such as the RAM, hard drive, or the motherboard, this guide will show you how to safely open the laptop for access to these components.
Partes
No se requieren partes.
  1. Flip the laptop over, such that the bottom of the laptop is facing upwards.
    • Flip the laptop over, such that the bottom of the laptop is facing upwards.
    • Ensure that the laptop is powered off prior to following this guide.
  2. Pull the latch to the right of the battery to the right. Pull the latch to the right of the battery to the right.
    • Pull the latch to the right of the battery to the right.
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing. Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing.
    • Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing.
  5. While holding the second latch from the previous step, use another hand to reach underneath the battery. Pull the battery upwards and away from the laptop to remove it.
    • While holding the second latch from the previous step, use another hand to reach underneath the battery.
    • Pull the battery upwards and away from the laptop to remove it.
  6. Using a JIS #00 screwdriver, unscrew the two 5 mm screws on either side of the laptop panel. Using a JIS #00 screwdriver, unscrew the two 5 mm screws on either side of the laptop panel.
    • Using a JIS #00 screwdriver, unscrew the two 5 mm screws on either side of the laptop panel.
  7. Remove the panel by pushing away from the laptop until the panel is free of the laptop. Lift to remove the panel. Lift to remove the panel.
    • Remove the panel by pushing away from the laptop until the panel is free of the laptop.
    • Lift to remove the panel.
Conclusión
Una persona más ha completado esta guía.
Elliott Beckner
Miembro Desde 05/11/18
525 Reputación
4 Guías creadas
Equipo
IUPUI, Team S2-G1, Baechle Fall 2018 Miembro de IUPUI, Team S2-G1, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G1
4 Miembros
5 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 10
Todo El Tiempo: 56
