Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Remove Permanent Marker Stains From a Whiteboard
Qué necesitas
    1. How to Remove Permanent Marker Stains From a Whiteboard, How to Remove Permanent Marker Stains From a Whiteboard: paso 1, imagen 1 de 1
      • The word ‘iFixit!’ is written down with a permanent marker.
      • Wait for 30 seconds until the ink is completely dry.
      Pregunta a FixBot
      Agregar Comentario
    2. How to Remove Permanent Marker Stains From a Whiteboard: paso 2, imagen 1 de 1
      • Apply on top of the stains with a dry erase marker to scribble through the stains.
      Pregunta a FixBot
      Agregar Comentario
    3. How to Remove Permanent Marker Stains From a Whiteboard: paso 3, imagen 1 de 1
      • Use an old cloth to wipe off as much of the ink as possible.
      Pregunta a FixBot
      Agregar Comentario
    4. How to Remove Permanent Marker Stains From a Whiteboard: paso 4, imagen 1 de 2 How to Remove Permanent Marker Stains From a Whiteboard: paso 4, imagen 2 de 2
      • Moisten the cloth with enough acetone to make it wet without over-pouring.
      • Wear gloves before using the acetone to protect your hands.
      Pregunta a FixBot
      Agregar Comentario
    5. How to Remove Permanent Marker Stains From a Whiteboard: paso 5, imagen 1 de 2 How to Remove Permanent Marker Stains From a Whiteboard: paso 5, imagen 2 de 2
      • Wipe the remaining permanent marker stains away with the cloth.
      • Keep wiping until the stains are completely gone.
      Pregunta a FixBot
      Agregar Comentario
    6. How to Remove Permanent Marker Stains From a Whiteboard: paso 6, imagen 1 de 2 How to Remove Permanent Marker Stains From a Whiteboard: paso 6, imagen 2 de 2
      • Check the whiteboard for other stains.
      • Repeat to wipe with acetone and the whiteboard can be reused again.
      Pregunta a FixBot
      Agregar Comentario
Linea de Meta
Una persona más ha completado esta guía.
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 28
Ultimos 30 días: 137
Todo El Tiempo: 876
