Saltar al contenido principal
How to Remove Makeup Stain from Shirt
Qué necesitas
  1. How to Remove Makeup Stain from Shirt, How to Remove Makeup Stain from Shirt: paso 1, imagen 1 de 1
    • Place a white napkin or rag under the shirt to avoid making a mess or colour transfer into the garment.
  2. How to Remove Makeup Stain from Shirt: paso 2, imagen 1 de 2 How to Remove Makeup Stain from Shirt: paso 2, imagen 2 de 2
    • Pour micellar water over the stain
    • Micellar water can be replaced by any kind of water-based makeup remover.
    • Do not use an oil-based makeup remover as it will permanently damage the shirt.
  3. How to Remove Makeup Stain from Shirt: paso 3, imagen 1 de 2 How to Remove Makeup Stain from Shirt: paso 3, imagen 2 de 2
    • Pat the stain dry with the napkin/rag from Step 1.
    • Do not use Kleenex tissues as they will fall apart and make a mess by sticking to the fabric.
  4. How to Remove Makeup Stain from Shirt: paso 4, imagen 1 de 1
    • Wash the shirt in cold water with the detergent of your choice.
  5. How to Remove Makeup Stain from Shirt: paso 5, imagen 1 de 1
    • Pour detergent over the stain. Pour baking soda or powder over the soap.
    • The recommended measurement is 1/4 of a teaspoon of baking soda/powder but you may use more if the stain is larger.
  6. How to Remove Makeup Stain from Shirt: paso 6, imagen 1 de 1
    • Scrub the paste into the shirt with a toothbrush.
  7. How to Remove Makeup Stain from Shirt: paso 7, imagen 1 de 1
    • Let rest for 15 minutes.
  8. How to Remove Makeup Stain from Shirt: paso 8, imagen 1 de 1
    • Wash the shirt in cold water followed by lukewarm water.
  9. How to Remove Makeup Stain from Shirt: paso 9, imagen 1 de 1
    • Let the shirt air dry and iron it if necessary.
Conclusión
Let the shirt air dry and iron as needed.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 26
Todo El Tiempo: 336
