Saltar al contenido principal
How to Refinish a Scratched Wood Table
Qué necesitas
  1. How to Refinish a Scratched Wood Table, How to Refinish a Scratched Wood Table: paso 1, imagen 1 de 3 How to Refinish a Scratched Wood Table, How to Refinish a Scratched Wood Table: paso 1, imagen 2 de 3 How to Refinish a Scratched Wood Table, How to Refinish a Scratched Wood Table: paso 1, imagen 3 de 3
    • Flip your table over on the tabletop or on the side if applicable.
    • Get your hex keys or screwdriver.
    • Using your tool to unscrew all of the legs on the table.
  2. How to Refinish a Scratched Wood Table: paso 2, imagen 1 de 2 How to Refinish a Scratched Wood Table: paso 2, imagen 2 de 2
    • Using a damp cloth, wipe down the tabletop and all of the legs.
  3. How to Refinish a Scratched Wood Table: paso 3, imagen 1 de 3 How to Refinish a Scratched Wood Table: paso 3, imagen 2 de 3 How to Refinish a Scratched Wood Table: paso 3, imagen 3 de 3
    • Get the 220 grit sandpaper and cut a smaller piece.
    • Sand the tabletop until all scratches are leveled with the wood.
    • Sand all of the legs.
    • You may use a sander if you do not want to sand the table by hand.
  4. How to Refinish a Scratched Wood Table: paso 4, imagen 1 de 1
    • Paint all of the legs and let them dry.
    • Be sure to mix your paint to ensure it hasn't separated before applying.
  5. How to Refinish a Scratched Wood Table: paso 5, imagen 1 de 1
    • Paint the tabletop and let it dry.
    • If using wood paint, coat the tabletop more than once.
  6. How to Refinish a Scratched Wood Table: paso 6, imagen 1 de 3 How to Refinish a Scratched Wood Table: paso 6, imagen 2 de 3 How to Refinish a Scratched Wood Table: paso 6, imagen 3 de 3
    • Line up the legs with the screw holes.
    • Hand tighten the screws and then use the hex keys or screwdriver to completely tighten.
    • Attach all legs and flip the table onto its legs.
Linea de Meta
Gurvir Boparai
Miembro Desde 01/10/22
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 14
Ultimos 30 días: 53
Todo El Tiempo: 1,139
