Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Recharge the A/C in a 2009 Infiniti G37
Qué necesitas
  1. How to Recharge the A/C in a 2009 Infiniti G37, How to Recharge the A/C in a 2009 Infiniti G37: paso 1, imagen 1 de 3 How to Recharge the A/C in a 2009 Infiniti G37, How to Recharge the A/C in a 2009 Infiniti G37: paso 1, imagen 2 de 3 How to Recharge the A/C in a 2009 Infiniti G37, How to Recharge the A/C in a 2009 Infiniti G37: paso 1, imagen 3 de 3
    • Locate the high and low-pressure ports.
    • The high-pressure port is located on the upper right (below the brake liquid).
    • The low-pressure port is located inside the brake liquid case (remove the case).
    Pregunta a FixBot
  2. How to Recharge the A/C in a 2009 Infiniti G37: paso 2, imagen 1 de 3 How to Recharge the A/C in a 2009 Infiniti G37: paso 2, imagen 2 de 3 How to Recharge the A/C in a 2009 Infiniti G37: paso 2, imagen 3 de 3
    • Connect the hoses to the gauge and the pressure ports.
    • Blue stands for low pressure.
    • Red stands for high pressure.
    • Yellow is where the new air flows through the two hoses.
    Pregunta a FixBot
  3. How to Recharge the A/C in a 2009 Infiniti G37: paso 3, imagen 1 de 3 How to Recharge the A/C in a 2009 Infiniti G37: paso 3, imagen 2 de 3 How to Recharge the A/C in a 2009 Infiniti G37: paso 3, imagen 3 de 3
    • Turn on the engine.
    • Turn the A/C to the maximum capacity.
    • Make sure the pulley belt is spinning smoothly to proceed.
    Pregunta a FixBot
  4. How to Recharge the A/C in a 2009 Infiniti G37: paso 4, imagen 1 de 2 How to Recharge the A/C in a 2009 Infiniti G37: paso 4, imagen 2 de 2
    • Turn off the vehicle.
    • Connect one end of the tee valve connector to your refrigerant and the other end to the yellow hose.
    • Turn on your vehicle again.
    Pregunta a FixBot
  5. How to Recharge the A/C in a 2009 Infiniti G37: paso 5, imagen 1 de 2 How to Recharge the A/C in a 2009 Infiniti G37: paso 5, imagen 2 de 2
    • Make sure the high-pressure nob is sealed.
    • Begin to add refrigerant by opening the nob.
    • To get the most refrigerant, shake the bottle side-by-side.
    Pregunta a FixBot
  6. How to Recharge the A/C in a 2009 Infiniti G37: paso 6, imagen 1 de 2 How to Recharge the A/C in a 2009 Infiniti G37: paso 6, imagen 2 de 2
    • Pump the refrigerant until the pressure gauge gets to 25- 45 psi. This process can take 10 minutes.
    • Do not go past 45 psi as the car can over-charge.
    • If you are using refrigerant mini cans, use the amount the car recommends. You can find this information inside the hood of the vehicle.
    Pregunta a FixBot
  7. How to Recharge the A/C in a 2009 Infiniti G37: paso 7, imagen 1 de 2 How to Recharge the A/C in a 2009 Infiniti G37: paso 7, imagen 2 de 2
    • Go inside your vehicle and check the temperature.
    • The temperature should be from 35-48 degrees Fahrenheit.
    • If the temperature is over what is recommended, the A/C will just be really cold. This will cause no problems.
    • Now that the temperature and air pressures are set, it's time to turn off your vehicle.
    • Proceed to remove all equipment (use safety gear).
    Pregunta a FixBot
Linea de Meta
Una persona más ha completado esta guía.
Brian Canas
Miembro Desde 04/04/22
145 Reputación
1 Guía escrita
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 16
Ultimos 30 días: 102
Todo El Tiempo: 5,736
