Saltar al contenido principal
How to Reattach the Head of a Mailbox to the Base
Qué necesitas
  1. How to Reattach the Head of a Mailbox to the Base, How to Reattach the Head of a Mailbox to the Base: paso 1, imagen 1 de 2 How to Reattach the Head of a Mailbox to the Base, How to Reattach the Head of a Mailbox to the Base: paso 1, imagen 2 de 2
    • Inspect the head of the mailbox to see where the detachment is located.
  2. How to Reattach the Head of a Mailbox to the Base: paso 2, imagen 1 de 2 How to Reattach the Head of a Mailbox to the Base: paso 2, imagen 2 de 2
    • Gather all materials needed.
    • Adhesive can be included depending on the tight fit you desire.
  3. How to Reattach the Head of a Mailbox to the Base: paso 3, imagen 1 de 3 How to Reattach the Head of a Mailbox to the Base: paso 3, imagen 2 de 3 How to Reattach the Head of a Mailbox to the Base: paso 3, imagen 3 de 3
    • Measure out the wood plank to match the length and width of the mailbox head.
  4. How to Reattach the Head of a Mailbox to the Base: paso 4, imagen 1 de 3 How to Reattach the Head of a Mailbox to the Base: paso 4, imagen 2 de 3 How to Reattach the Head of a Mailbox to the Base: paso 4, imagen 3 de 3
    • Use a hammer or mallet to nail this wood plank to the bottom of mailbox head. Use at least four nails for this task.
    • Use gloves, if deemed necessary!
  5. How to Reattach the Head of a Mailbox to the Base: paso 5, imagen 1 de 2 How to Reattach the Head of a Mailbox to the Base: paso 5, imagen 2 de 2
    • Screw the sides down for a stronger fit using at least four screws.
  6. How to Reattach the Head of a Mailbox to the Base: paso 6, imagen 1 de 1
    • Align the mailbox head back on the post.
  7. How to Reattach the Head of a Mailbox to the Base: paso 7, imagen 1 de 2 How to Reattach the Head of a Mailbox to the Base: paso 7, imagen 2 de 2
    • Hammer down the head to the post of the mailbox with at least three more nails.
    • Add adhesive if necessary for a sturdier attachment.
    • Since your hands are inside the mailbox, it may be best to use gloves for this task.
Linea de Meta
Terrell Cobbins
Miembro Desde 03/21/23
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 34
Todo El Tiempo: 349
