Saltar al contenido principal
How to Reattach a Canvas Tote Bag Strap
Qué necesitas
  1. How to Reattach a Canvas Tote Bag Strap, How to Reattach a Canvas Tote Bag Strap: paso 1, imagen 1 de 1
    • Trim off any loose strings or threads attached to the ends of the strap and tote bag body.
  2. How to Reattach a Canvas Tote Bag Strap: paso 2, imagen 1 de 1
    • Use a ruler to measure the distance from the end of an attached strap to the edge of the bag.
  3. How to Reattach a Canvas Tote Bag Strap: paso 3, imagen 1 de 1
    • On the side where the tote bag strap has detached, put a mark based on your previous measurement on the inside of the bag.
    • This mark is where you want to start sewing your strap.
  4. How to Reattach a Canvas Tote Bag Strap: paso 4, imagen 1 de 2 How to Reattach a Canvas Tote Bag Strap: paso 4, imagen 2 de 2
    • Cut a piece of thread that is about 22–24 inches in length.
    • Pull the thread through the needle eye until the two ends of the thread are equal.
    • Double knot the two ends of the thread together.
  5. How to Reattach a Canvas Tote Bag Strap: paso 5, imagen 1 de 2 How to Reattach a Canvas Tote Bag Strap: paso 5, imagen 2 de 2
    • Begin sewing by weaving the needle down through the strap material and then upwards through the strap material.
    • Sew half an inch above the bottom edge of the tote bag strap in a straight line all the way across to the other end of the strap.
    • Sew about 2-3 lines with the thread. You may add more or less depending on how much strength you think it will need.
    • Stitches should be about 1-2 mm apart.
    • When sewing through the tote bag material, be careful of finger tips since needle is sharp.
    • Here is a link to an external site that will provide more detail on how to sew, along with different methods. https://www.wikihow.com/Sew
  6. How to Reattach a Canvas Tote Bag Strap: paso 6, imagen 1 de 1
    • Tie off the thread by making a secure knot at the end.
  7. How to Reattach a Canvas Tote Bag Strap: paso 7, imagen 1 de 2 How to Reattach a Canvas Tote Bag Strap: paso 7, imagen 2 de 2
    • Cut off the extra thread.
    • Once you finish, your tote bag should look like this.
Conclusión
Repeat all of the steps for any remaining detached straps.
Jasmine Phan
Miembro Desde 02/02/23
145 Reputación
1 Guía escrita
Equipo
UC Davis, Team 4-1, Andersen Winter 2023 Miembro de UC Davis, Team 4-1, Andersen Winter 2023
UCD-ANDERSEN-W23S4G1
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 35
Ultimos 30 días: 144
Todo El Tiempo: 1,738
