Saltar al contenido principal
How to Reattach a Cabinet's Center Stile
Qué necesitas
  1. How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: paso 1, imagen 1 de 3 How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: paso 1, imagen 2 de 3 How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: paso 1, imagen 3 de 3
    • Measure the width and length of the detached center stile.
  2. How to Reattach a Cabinet's Center Stile: paso 2, imagen 1 de 3 How to Reattach a Cabinet's Center Stile: paso 2, imagen 2 de 3 How to Reattach a Cabinet's Center Stile: paso 2, imagen 3 de 3
    • Mark the measurements on the wood block that will be the supporting piece.
    • You may need to extend the length of the new stile to cover several inches above and below the stile's point of attachment.
    • Follow the markings and use the hacksaw to cut down the wood block so that it is the same width as the center stile.
  3. How to Reattach a Cabinet's Center Stile: paso 3, imagen 1 de 3 How to Reattach a Cabinet's Center Stile: paso 3, imagen 2 de 3 How to Reattach a Cabinet's Center Stile: paso 3, imagen 3 de 3
    • Apply a generous amount of wood glue to one side of the wood block.
    • Spread the glue to cover the entire side of the wood.
  4. How to Reattach a Cabinet's Center Stile: paso 4, imagen 1 de 2 How to Reattach a Cabinet's Center Stile: paso 4, imagen 2 de 2
    • Place the wood piece against the back of stile and cabinet frame.
    • Use clamps to hold the center stile, cabinet frame, and wood supporting piece together.
    • The clamps prevent the wood block from sliding off the center stile so that it will dry in a fixed position.
    • Remove the clamps after 24 hours.
Linea de Meta
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 19
Ultimos 30 días: 62
Todo El Tiempo: 1,183
