Introducción
This guide will show you how to realign a guitar neck by adjusting the truss rod. The guitar used in this guide is a Dean acoustic guitar, but this procedure may be applied to different models.
The neck can become misaligned due to thermal expansion and can happen when the guitar is not stored properly. Playing a guitar with a misaligned neck may result in buzzing sounds and can be difficult to play comfortably.
Qué necesitas
Un comentario
This is all wrong.
What's being done here is tightening the truss rod, which does NOT align the neck. You cannot change the distance between the bridge and the strings.
You do not want to fool with the truss rod unless you understand what it does and how to tell that you're doing it correctly, and this "guide" does not even begin to explain any of that.
