Introducción
If your Finalkey V65 keyboard stabilizers start sounding rattly, use this guide to learn how to lube them and remove the rattle.
The keyboard's stabilizers contain small plastic and metal parts, and a rattly stabilizer results from a bad lubing job, or the lube may have dried over time with use.
Before starting this guide, ensure that your keyboard is unplugged to avoid damaging the port and make it easier to disassemble.
Qué necesitas
Start the disassembly process by removing all the keycaps on the keyboard.
To use a keycap puller, insert the tool's wires beneath the edges of the keycap you want to remove, ensure a secure grip, and gently lift to detach the keycap from the keyboard switch.
