Saltar al contenido principal
How to Put an iPhone Into Recovery Mode
  1. How to Put an iPhone Into Recovery Mode, Connect to a Computer: paso 1, imagen 1 de 1
    • Using a USB cable, connect your iPhone to a Mac or PC with the most current version of iTunes installed.
  2. How to Put an iPhone Into Recovery Mode, Button Combination Press: paso 2, imagen 1 de 1
    • If you have an iPhone 8 or later: press and release the Volume Up button, press and release the Volume Down button, press and hold the Side button until you see the Recovery Mode screen
    • For an iPhone 7 or 7 Plus: Press and hold the Side button and Volume Down button until you see the Recovery Mode screen.
    • On iPhone 6s or earlier: Press and hold both the Power button and the Home button until you see the Recovery Mode screen.
  3. How to Put an iPhone Into Recovery Mode, Recover the device: paso 3, imagen 1 de 2 How to Put an iPhone Into Recovery Mode, Recover the device: paso 3, imagen 2 de 2
    • For macOS Catalina and Later: Open Finder. In the sidebar, you will see your device. When you click on it, a pop up will appear prompting for Update or Restore. Update will reinstall the OS without erasing data. If the update option fails or you are locked out of your device, restore will reinstall the OS and erase all data.
    • For macOS Mojave and Prior or Windows: Open iTunes. In the top left corner will be an icon for the iPhone. When you click it, a popup will appear prompting to Update or Restore. Update to reinstall the OS without erasing data. If the update option fails or you are locked out of your device, restore will reinstall the OS and erase all data.
Conclusión
To put your iOS device in recovery mode, follow these instructions.
9 personas más completaron esta guía.
Duckida
Miembro Desde 02/07/20
592 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 44
Ultimos 7 días: 412
Ultimos 30 días: 1,722
Todo El Tiempo: 14,471
