Saltar al contenido principal
How to Properly Clean the Airox Legendair
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
Qué necesitas
  1. How to Properly Clean the Airox Legendair, How to Properly Clean the Airox Legendair: paso 1, imagen 1 de 1
    • First, switch off the device.
    • Place the device in a clean and open environment.
  2. How to Properly Clean the Airox Legendair: paso 3, imagen 1 de 1
    • Using a cloth or a sponge slightly dampened with a bactericide or germicide solution, gently clean the outside of the device.
  3. How to Properly Clean the Airox Legendair: paso 4, imagen 1 de 1
    • If necessary, spray the device lightly with the germicide solution, taking account of the requirements discussed in the preliminary operations.
    • Do not allow any liquid to enter inside the device (in particular through the cooling apertures).
    • Use a gentle air blast to clear away any remaining liquid from ventilator.
Conclusión
Make sure the ventilator is in good visual condition upon thorough cleaning of the machine.
Equipo
Cal Poly, Team S7-G15, Paton Spring 2020 Miembro de Cal Poly, Team S7-G15, Paton Spring 2020
CPSU-PATON-S20S7G15
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 120
