1. Find the power cord.
    • Find the power cord.
    • Make sure that it is unplugged from the outlet. This is to make sure that no power is flowing through and you are not injured.
  2. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Check to make sure that the power cord is connected to the device. If it is not connect the smaller end to the back of the device.
    • Check to make sure that the power cord is connected to the device. If it is not connect the smaller end to the back of the device.
  4. Check to make sure that the power cord is connected to an outlet. If not, take the two-pronged end and plug it in to an outlet. The device is now correctly plugged in.
    • Check to make sure that the power cord is connected to an outlet. If not, take the two-pronged end and plug it in to an outlet. The device is now correctly plugged in.
Conclusión
Equipo
Cal Poly, Team 7-50, Forte Fall 2012 Miembro de Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Miembros
8 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 196
