Saltar al contenido principal
Envío gratis en pedidos nacionales de $75+
How to Patch a Hole in a Plastic Trash Can
Vistas: 5.7 k
Ver estadísticas:
Últimas 24 horas:
5
Últimos 7 días:
43
Últimos 30 días:
227
Todo El Tiempo:
5,724
Comentarios: 0
Nadie ha escrito comentarios en esta guía. ¿Quieres escribir el primero?
Ir a los comentarios de la guía
Completado: 1
1 persona ha marcado esta guía como "completada". ¿Serás tú la próxima persona en hacerlo?
Favoritos: 0
Nadie ha marcado como "Favorita" ni se ha suscrito a esta guía. ¿Quieres hacerlo tú?
Tiempo Requerido: 1 - 2 horas
Dificultad: Moderado
Introducción
Ir al paso 1 ↓
Smaller trash cans are prone to plenty of wear and tear in the home, especially when bulky waste items warp it to the point of splitting. Splits can become holes with even more wear. Damaged trash cans can appear to be of no use; however, instead of creating more waste by tossing a working trash can, use this guide to help you repair your trash can to prolong its lifespan in your home.
    1. How to Patch a Hole in a Plastic Trash Can, How to Patch a Hole in a Plastic Trash Can: paso 1, imagen 1 de 3 How to Patch a Hole in a Plastic Trash Can, How to Patch a Hole in a Plastic Trash Can: paso 1, imagen 2 de 3 How to Patch a Hole in a Plastic Trash Can, How to Patch a Hole in a Plastic Trash Can: paso 1, imagen 3 de 3
      • Remove any obstructions such as labels.
      • Wipe down your trash can to ensure there is no debris on the surface.
      Pregunta a FixBot
      Agregar Comentario
    2. How to Patch a Hole in a Plastic Trash Can: paso 2, imagen 1 de 2 How to Patch a Hole in a Plastic Trash Can: paso 2, imagen 2 de 2
      • Cut a piece of duct tape equal to the length of the cracks and/or holes on your trash can.
      • You may need more than one piece of tape if the damage is significant.
      • Place the duct tape on the inside where the damage is present.
      Pregunta a FixBot
      Agregar Comentario
    3. How to Patch a Hole in a Plastic Trash Can: paso 3, imagen 1 de 3 How to Patch a Hole in a Plastic Trash Can: paso 3, imagen 2 de 3 How to Patch a Hole in a Plastic Trash Can: paso 3, imagen 3 de 3
      • This step deals with material that can be harmful if inhaled and/or it makes contact with your skin. It is with utmost importance that you wear proper PPE (personal protective equipment). Disposable gloves and an N95 face mask are highly recommended.
      • Follow the instructions on the back of the Bondo Short Strand Fiberglass Filler label for proper measurements of the filler.
      • Add in a sufficient amount of Bondo Cream Hardener according to the Bondo Fiberglass Filler label.
      • Mix together until this mixture becomes a single color.
      Pregunta a FixBot
      Agregar Comentario
    4. How to Patch a Hole in a Plastic Trash Can: paso 4, imagen 1 de 3 How to Patch a Hole in a Plastic Trash Can: paso 4, imagen 2 de 3 How to Patch a Hole in a Plastic Trash Can: paso 4, imagen 3 de 3
      • Use a 1/2" plastic putty knife to apply the mixture to the outside of your trash can.
      • If the surface of your trash can is extremely smooth, sand the area around the damage before applying the mixture to allow it to adhere better to the surface.
      • This mixture will begin to harden within 3 to 4 minutes, so work as fast as you can to get an even layer on the surface.
      • Allow the mixture to cure on your trash can for at least 30 minutes.
      Pregunta a FixBot
      Agregar Comentario
    5. How to Patch a Hole in a Plastic Trash Can: paso 5, imagen 1 de 2 How to Patch a Hole in a Plastic Trash Can: paso 5, imagen 2 de 2
      • Once the mixture has fully cured, use a strip of 80 grit sandpaper to sand the hardened mixture.
      • In addition to wearing a mask, this step should be done outdoors or in a properly ventilated area to reduce the risk of inhaling the sanded debris.
      Pregunta a FixBot
      Agregar Comentario
    6. How to Patch a Hole in a Plastic Trash Can: paso 6, imagen 1 de 2 How to Patch a Hole in a Plastic Trash Can: paso 6, imagen 2 de 2
      • When you're satisfied with your sanding job, remove the duct tape from inside the trash can.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Now you're done!
Una persona más ha completado esta guía.
Autor
con
Suzy Lee
Miembro Desde 02/21/24
210 Reputación
1 Guía escrita
Equipo
CSU Sacramento, Team G-9, Laflen Spring 2024 Miembro de CSU Sacramento, Team G-9, Laflen Spring 2024
CSUSAC-LAFLEN-S24SGG9
Miembros de 2
12 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 43
Ultimos 30 días: 227
Todo El Tiempo: 5,724
