Saltar al contenido principal
How to Patch a Hole in Jeans with Wool
Qué necesitas
  1. How to Patch a Hole in Jeans with Wool, Patching a hole in Jean: paso 1, imagen 1 de 3 How to Patch a Hole in Jeans with Wool, Patching a hole in Jean: paso 1, imagen 2 de 3 How to Patch a Hole in Jeans with Wool, Patching a hole in Jean: paso 1, imagen 3 de 3
    • Cut a piece of felt large enough to cover the hole
  2. How to Patch a Hole in Jeans with Wool: paso 2, imagen 1 de 2 How to Patch a Hole in Jeans with Wool: paso 2, imagen 2 de 2
    • Insert thread through the needle hole.
  3. How to Patch a Hole in Jeans with Wool: paso 3, imagen 1 de 3 How to Patch a Hole in Jeans with Wool: paso 3, imagen 2 de 3 How to Patch a Hole in Jeans with Wool: paso 3, imagen 3 de 3
    • Make a loop at the end of the thread.
    • Pull the end of the thread through the loop creating a knot.
  4. How to Patch a Hole in Jeans with Wool: paso 4, imagen 1 de 3 How to Patch a Hole in Jeans with Wool: paso 4, imagen 2 de 3 How to Patch a Hole in Jeans with Wool: paso 4, imagen 3 de 3
    • Grab the end of the jean with your hand.
    • Pull the jean towards you, making it inside out.
    • Place the felt on the hole.
  5. How to Patch a Hole in Jeans with Wool: paso 5, imagen 1 de 3 How to Patch a Hole in Jeans with Wool: paso 5, imagen 2 de 3 How to Patch a Hole in Jeans with Wool: paso 5, imagen 3 de 3
    • Pinch together the jean and the felt.
    • Insert the needle horizontally into the jean and edge of the felt.
    • Pull the needle through till the knot touches the felt.
    • Repeat the above steps until the border of the felt is stitched.
    • Make a knot at the end.
    • Cut off excess thread.
  6. How to Patch a Hole in Jeans with Wool: paso 6, imagen 1 de 3 How to Patch a Hole in Jeans with Wool: paso 6, imagen 2 de 3 How to Patch a Hole in Jeans with Wool: paso 6, imagen 3 de 3
    • Grasp the end of the jeans and pull them towards you to turn them right side out.
    • Insert the foam board into the pants and position it underneath the hole.
  7. How to Patch a Hole in Jeans with Wool: paso 7, imagen 1 de 3 How to Patch a Hole in Jeans with Wool: paso 7, imagen 2 de 3 How to Patch a Hole in Jeans with Wool: paso 7, imagen 3 de 3
    • Grab more than enough wool to cover the size of your hole, ensuring it is at least an inch thick.
    • Rub the wool between hands to make a ball.
    • Place the wool on top of the hole.
  8. How to Patch a Hole in Jeans with Wool: paso 8, imagen 1 de 3 How to Patch a Hole in Jeans with Wool: paso 8, imagen 2 de 3 How to Patch a Hole in Jeans with Wool: paso 8, imagen 3 de 3
    • Stab the wool through the jean and onto the foam board.
    • Repeat until the wool is hardened.
  9. How to Patch a Hole in Jeans with Wool: paso 9, imagen 1 de 3 How to Patch a Hole in Jeans with Wool: paso 9, imagen 2 de 3 How to Patch a Hole in Jeans with Wool: paso 9, imagen 3 de 3
    • Rub some soap onto the wool to tangle the fibers.
    • Place the jeans into the laundry machine.
    • Wash on cold and air dry.
    • Wear your cute mended pants!
Linea de Meta
LiTong Liu
Miembro Desde 04/25/24
169 Reputación
1 Guía escrita
Equipo
UC Davis, Team 1-2, Whithaus Spring 2024 Miembro de UC Davis, Team 1-2, Whithaus Spring 2024
UCD-WHITHAUS-S24S1G2
3 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 22
Ultimos 30 días: 77
Todo El Tiempo: 208
